Old 11-13-2021, 01:52 AM   #1
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
increasing / decreasing shift firmness
Hey guys so I'm running into a little problem with my 6l80. I got everything the way I want it except for the shift firmness on the 2-3 and 3-4 shifts. The 2-3 is too firm and the 3-4 is too soft. I first to tried adjusting the adaptive oncoming pressure presets by lowering the pressure on 2-3 and raising it on the 3-4 but it did nothing that I could tell. I then tried raising the shift time for the 2-3 shift and lowering the time on the 3-4 but did nothing either. Now I'm gonna try lowering the base shift pressure on the 1-2 and raising it on the 3-4. Any other things I should try? Thanks
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 11-15-2021, 04:08 PM   #2
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
My tried and true plug for someone else's program.
Bluecats and watch the tutorials on YouTube.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 12-01-2021, 02:28 AM   #3
morepowerjoe
To answer my own question, what you want to do is under the torque factor tab.
