Old 11-14-2021, 05:35 PM   #1
Blubird68
Drives: 1993 z28/2010 2SS
Non-RS to RS headlight swap
So I did the swap yesterday, everything went pretty easy and smooth. I used the gen5diy harness, but I can’t get the halos to come on at all. Is there something else I need to do ?
Blubird68 is offline   Reply With Quote
Old 11-17-2021, 01:34 PM   #2
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
I did mine a few years ago with that harness and also did a friend's car recently, both turned out great. What fuse did you get power from the fuse box? Can you post a pic?
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM,
DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick,
ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop,NPP cat-back,
GM 3.91 gears, Eaton Truetrac, etc.
PhantomBlack is offline   Reply With Quote
Old 11-17-2021, 06:50 PM   #3
Blubird68
Maybe I got the wrong harness then, I just got the halos on with headlights harness. Maybe I should have got the halos always on harness
Old 11-17-2021, 09:43 PM   #4
PhantomBlack
I just realized you have a 2010. From the factory 2010-2013 had the halos only come on with the headlights on correct? I've only done the harness on the 2014-2015 models. Which by default the halos are always on regardless.
Old 11-17-2021, 11:36 PM   #5
Junker80
Junker80's Avatar
Drives: 2010 Camaro 2SS/RS M6
I have a "Halos Always on" harness for sale on here If you need one.
Junker80 is offline   Reply With Quote
Old 11-18-2021, 06:25 PM   #6
Blubird68
Yeah I’m not sure then, i got both lights off separate cars so it would be strange or a bad coincidence that both didn’t work. I’ve tried all the settings and switching between low and hi’s. I have the other harness on the way with the fuse so maybe that will fix the issue
Old 11-19-2021, 08:40 PM   #7
Blubird68
Yeah that still didn’t work, I don’t know what’s causing it. Haven’t heard of this issue before so just my luck
Old 11-20-2021, 12:24 PM   #8
PhantomBlack
Gen5diy has good customer support with issues like this. Have you given them a call yet to talk you through installation?
Old 11-20-2021, 07:23 PM   #9
Blubird68
No but I have emailed them
Old 12-03-2021, 07:07 PM   #10
Blubird68
UPDATE: got the halos to turn on 😃
I ended up removing the 15 fuse and putting the add a fuse in there. It’s weird. I tried it originally on a different fuse and it didn’t work for some reason
Old 12-05-2021, 11:17 AM   #11
PhantomBlack
Nice! Glad it was a simple solution for you!
