11-18-2021, 02:48 PM | #1 |
Drives: 11 Camaro SS, Ninja 1000, Santa Fe Join Date: Sep 2020
Factory radio no longer playing with iPhone cord connection
I have a factory radio in my 2011 Camaro SS. After upgrading my iPhone to the latest software the plug-in audio no longer works. I did a little research and others have had the same issue. I know my answer is to upgrade the radio but I was hoping not to have to do that. Has anyone else had this happen and actually solved it? I know I can convert to the audio jack option but that would no longer charge and allow the steering wheel controls.
Just posting here in case there was some wiz out there that found a solution for this.
11 Camaro TT SS. 14 1LE motor, full coilover, CNC ported LSA heads, stainless valves, dual springs, Comp 224 cam, Melling oil pump, AGP Garrett GTX30r's, 1400cc injectors, full 3" Magnaflow, dual Walbro 450lph fuel pump, ZL1 6L90 trans, trans cooler, Circle-D 3600, 3.91:1 Eaton Truetrac, line lock, Lingenfelter 2 step. Current boost - e85 814 RWHP.
11-18-2021, 08:31 PM | #2 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
I had a similar issue but mine was caused from upgrading my phone and not having a hole to plug the radio into my phone.
So now I just blue tooth it. |
