![]() Drives: 2010 Camaro 2SS/RS ABM Join Date: Apr 2017
Bent Driveshaft? Mount issues? HELP!
Hey guys,
I explained the following to my mechanic over the phone and he suspects my problem could be related to possible bent driveshaft or perhaps something called a sinister mount bearing? (I'm confirming tomorrow) but I want some council prior to. [ THE PROBLEM ] My 2010 SS Camaro's (117k miles ) gear shifter is shaking a lot more than usual. All the symptoms + details. * I took my car to the shop about a month ago to do some gasket replacements. one of them being the oil pan gasket. I ask to check the clutch since its been about 25k miles and I wanted them to inspect it (nothing wrong in the end). They assembled it and returned it to me. Days later, shifter feels off and I hit a bump (not a big bump) and the shifter came our of 3rd gear and went to neutral. So it popped out of gear. I could basically apply little force to any gear and it'll switch to neutral without engaging the clutch (like theres no resistance). ----- 1) the shifter wobbles a lot during 20-40 mph then as speed increases it doesn't wobble as much. 2) no resistance when car is in a gear (hence why I believe any movement could pop it out of gear to neutral). Again I dont need to engage clutch for it to come out of gear. 3) I can still shift normally and the car doesn't lock out of gear. 4) The car vibrates (not OVERLY aggressive or shuttering) when I accelerate and at around 60mph but that is because i haven't aligned the car in 2 1/2 years and I'm due for it. I hear no clunking or any vibration directly underneath the car (like specifically caused by a bent shaft). Also no problems turning. Could something be loose after the gasket install? Any advice, guidance or direction is IMMENSELY appreciated. |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
I think he meant center, not sinister. We have a two piece driveshaft with a center support bearing.
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Been in the driveshaft industry 46 years. While they certainly can and do bend, I’d check the flex disk (‘guibo’ ‘donut’, etc) mount bolts. The black flex disks (at trans and diff) with six mount holes are effectively the ‘u-joints’ in the shaft.* Although there is an actual u-joint in the center. These bolts coming loose are a known problem, especially if someone removed the driveshaft once and reused the hardware and-or didn’t retorque properly.
*u-joints aren’t used on the ends because there is nearly a zero angle that the shaft passes through.
#4 | |
#6 | |
I’ve seen all metal ‘guibos’ in other applications. Kind of a laminated series in a six point star shape. I believe that was a static pump driveshaft of some sort. The rubber helps dampen torsional vibration in an automotive app.
#7 | |
I took it to the mechanic. He just drove it, and pointed to that center support bearing for the drive shaft. I told him I wanted him to check the car thoroughly on tuesday. He also said that it's a sold together and it's not sold separately, is that true? I just dont see how that bearing can only really be messing with the gear shifter causing it to wobble... yeah there's some vibration, but it feels no different than the vibration I had months ago. I don't hear any clanking or anything either. In the meantime, I want to be able to inspect on my own. I'll try to have a look at the things you mentioned. |
#8 | |
#9 |
Is it possible to buy the center piece bearing without having to buy a whole new drive shaft like they suggest? Or is it not worth doing that?
#10 |
I'll have to do some digging, but I think I saw somewhere on here that the center portion can be replaced. I'll also check with my Chevy mechanic tomorrow and see if I can get a part number for it. I replaced my driveshaft with a 1 pc aluminum one from DSS..
#11 | |
Yeah man any help is beyond appreciated. I seriously don't want to buy a new shaft if not necessary. Are you in the south florida area? If you know a mechanic down here I'd love a second opinion and perhaps an install job. Thank you!! |
#12 | |
https://www.gmpartsdirect.com/oem-pa...aring-22810753
| Tags |
| bearings, drive shaft, loose, mounts |
