Old 11-27-2021, 09:03 AM   #1
Marknbacon
Drives: 2015 camaro SS
Non-RS DRL questions
Alright, so I'm planning on doing some modifications to my headlights. I have a NON-RS, 2SS 2015 camaro. Right now I have LEDs in both high and low beam headlights. I would like to convert it to the RS style with Halos and/or projectors, although I'm not super attached to the idea of HIDs, so I may just go with a projector style beam.
What are you all running? What did you use to convert?
I'm not opposed to doing the wiring myself. In fact I have already ordered an additional relay box to run my aftermarket gauges off of (right now AFR and soon Fuel Pressure, and hopefully one day, boost ) as I don't really have room in the interior fuse block to put another tap circuit other than the one from the auxillary circuit running power to the wideband, which I will change to it simply being there to activate the relays when the ignition is on on a couple of relays. I've got room for 6 total relays.
Anyway, what I really need to figure out is how to separate the DRLs from the headlight circuit. I was thinking having the DRLs go to the fogs, the "Halos" (If I go that route) or maybe even wire in some demon eyes as "DRLs" (I don't believe TN has a mandatory DRL law)
What I was thinking on how to separate them is using the tail light circuit to activate a relay that would switch the headlights between non-headlight DRLs and the actual headlights, which should retain the factory automatic headlight control. Right now the headlights are just always on when the car is on unless I turn the headlights off completely. *EDIT* I remembered the side markers I believe only come on when the headlights are actually on vs DRL. I could tap into that circuit as well. *EDIT AGAIN* well now I don't remember if it comes on during the day or not... I'm going to have to check soon lol.
Another thing that would be helpful if anyone has them is the wiring diagrams for the headlight, drl, fog lamp, and tail light/stop light circuits on a 2014/2015.
Thoughts? Ready made solutions I haven't found yet? Anything? TIA.
Last edited by Marknbacon; 11-27-2021 at 09:09 AM. Reason: adding a comment to the comment.
Marknbacon is offline   Reply With Quote
headlight conversion, non rs, wiring, wiring diagram
