![]() Drives: 2012 Camaro 2ss 45th anniversary Join Date: Nov 2021
Oil type for 2012 ss
I was wondering if you guys recommended another viscocity oil for my 6 spd 2012 2ss. Its an ls3 I know it recommends 5w30 but I didn't know if you guys recommended another viscocity. The reason I ask is because my truck runs 5w30 but I've heard people say to put 10w30 in it just because the motor runs better on it in the long run. I might sound stupid im sorry dont bash me. Just need help.
It don’t come easy.
I would recommend using what your manual tells you. 5w30.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I would stick with the 5w30, no reason to change it. Besides, the 10W is just the cold viscosity, so it is very close to the 5w your manual specs for, and nearly identical at operating temperature.
I run 10w30 Amsoil Z-Rod in mine, but it's in a rebuilt LS3 with a cam. If Amsoil made Z-Rod in a 5w I would likely be running that. But since they don't I run the closest thing, which is the 10w30.
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
I have a '13 LFX and run Amsoil 5W30 XL (the middle grade of Amsoil, just a step below the Signature Series). I drive A LOT of highway miles and change the oil every 12K. I have over 151,300 miles on the car now and it still runs like a top.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
5w30
#6 |
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
GM probably doesn't care if your motor makes it to 200,000 miles, just past the warranty. I would run the best brand oil possible and for a close tolerance V8 5W20 would be my go to. If it had a lot of miles then 5W30.
My LFX gets the 0W16 for direct injection motors. Yeah, GM used the wrong oil in these too. ![]() Edit- 0W16 not 0W6.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
#7 | |
![]() Drives: 2014 Camaro 1LT Join Date: Aug 2019
I've heard this statement said about older vehicle engines, but it is a thing of the past. Modern engines require light synthetic oil and are very sensitive to the viscosity, at least what I've been told by my mechanic buddies. As such, I always (always) use the recommended viscosity. |
#8 |
5-30 Mobil 1 Synthetic since day one...
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I see much thicker weights are recommended for the track by GM and builders. I was thinking of going to a 5W 40 in a top tier oil ( Sig Series ) I only drive my car in the warm weather and believe a lot of wear occures at start up which would still be a 5 W.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
5-30 Mobil 1 from new.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
The higher warm weight is probably due to the expected increased running temperature on the track so that the 40 viscosity when operating at the higher temp is the same as 30 under "normal" conditions. I'm not sure that you will see a high enough temperature in NY in normal road use to justify. Maybe during a heat wave in southern Arizona.
#12 | |
Simply magic at the time.
#13 |
![]() Drives: 2013 Camaro Join Date: Feb 2016
| Tags |
| oil |
