11-29-2021, 09:58 PM | #1 |
Drives: 2013 ZL1 & 2012 2SS Join Date: Nov 2021
Just Picked Up A ZL1!
Hello, I just purchased a Yellow 2013 ZL1! What a freaking cool car. It only has 17K miles on it. Super excited about this car! For all you ZL1 owners out there is there anything I should know about this car? Cool features that aren’t obvious? This is all new to me on this one!
Ill post some pics tomorrow. I just got it today and its dark. Thank you!
2013 Chevy Camaro ZL1 Yellow Completely Stock. Brand New To Me
2012 Chevy Camaro 2SS/RS, LS3, GPI SS1 Cam, GPI Cam Kit, LS9 Head Gasket, Upgraded Valley Cover, Upgraded Crank Bolt, Lifter Trays, CHE Trunnion Kit, BTR Platinum Valve Springs, GPI Hardened Push Rods, GPI Phase Limiter, Upgraded Lifters, Corsa Dual Exhaust, Cold Air Intake, Headers. |
11-30-2021, 12:31 AM | #2 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
12-01-2021, 12:10 AM | #3 |
KaBoom1701
Most important thing if it's running stock tires is to make sure they are warm before getting on it. Dont wrap it around a pole on day one.
Watch the GM videos on PTM modes. Good info there. Great car is stock mode but if you add a few basic mods the car wakes up real fast. The LSA engine is amazing.
Mods:
12-01-2021, 12:53 AM | #4 | |
Also what mods are you talking about? Intake, headers, exhaust? Anything else that’s basic that helps? So excited to have this car and the LSA!
12-01-2021, 08:56 PM | #5 |
Drives: 2013 AGM ZL1, '70 Chevelle 454 Join Date: Apr 2019
So how does the ZL1 compare to the 2012 you have? I upgraded from a 4th gen, huge difference!
I know a cam really wakes up the ss. |
12-01-2021, 10:31 PM | #6 |
Drives: Camaro ZL1 Join Date: Sep 2021
I have long tubes and an intake for it if you’re interested dm me.
It has launch control and no lift shift from the factory which is awesome! |
12-01-2021, 11:42 PM | #7 | |
That being said the 2012 SS still feels like it has more power. A noticeable difference. But ya I haven’t gotten way into the ZL1 yet. But I have a feeling the SS is still going to be more of a beast for now.
12-02-2021, 09:29 PM | #8 |
KaBoom1701
CAI and 10% overdrive pully is the min.
I'd install a catch can to prevent the blow bye oil from being recycled back into your engine. You can read my mod list below for a good guild but then your into tune territory.
Mods:
12-02-2021, 10:34 PM | #9 |
Big Crow
If your ZL1 is low on supercharger coolant which is common you might be losing some hp.
Factory stock ZL1 auto is around 480wheel hp. Your SS should be around 445whp, so you can see seat of the pants might not be so different. The positive displacement supercharger makes the instant power at midrange you won't get in the SS that can be fun to spin tires. The sweet spot in the ZL1 has been mentioned, to add 75hp or more, and e85 is a fun add on albeit not on a low budget because it requires more injector and fuel pump solution. There are good reasons to keep the ZL1 stock. The smile factor goes way up when its awakened with another 75hp+ or more added. The NA car is limited to what streetable and budget hp you can make https://www.camaro5.com/forums/showthread.php?t=599964 I'm not saying the SS isn't going to be fun, that's what I'd do to one if I had it, just that the ZL1 is capable of much more if that's where you want to be. |
12-03-2021, 12:10 AM | #10 | ||
Thank you for the info. And I apologize but what would add 75HP? I’m assuming The headers and intake? Is that what you mean by sweet spot? I would love to add another 75! That would be awesome. And I do agree. The SS is much more limited which is why I wanted the ZL1. For the potential and the fact that it should be higher HP stock than my SS. Along with not having to dig into the motor to wake it up like the SS. It’s only got 17K miles on it so I dont think it would be low on supercharger coolant but maybe? I haven’t had much play time with it. I’d like to try sport mode and or turn all modes off for the raw car itself to test it. I definitely want that smile factor your talking about
2012 Chevy Camaro 2SS/RS, LS3, GPI SS1 Cam, GPI Cam Kit, LS9 Head Gasket, Upgraded Valley Cover, Upgraded Crank Bolt, Lifter Trays, CHE Trunnion Kit, BTR Platinum Valve Springs, GPI Hardened Push Rods, GPI Phase Limiter, Upgraded Lifters, Corsa Dual Exhaust, Cold Air Intake, Headers. Last edited by Camaro23$$; 12-03-2021 at 12:50 AM. |
12-03-2021, 08:13 AM | #11 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
12-03-2021, 08:27 AM | #12 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
ZLs handle and steer very well. I agree, make sure that you have adequate heat on your tires. If you are vain about appearance, you may want to look at some rock chip protection products in your travels.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
12-03-2021, 12:01 PM | #13 |
Oh ok so no headers? That makes it easy. Thank you for clarifying. Now to look for a tuner? GPI says they wont remote tune a ZL1 due to to many variables. I have no clue where to go where I am located in Spokane WA area. Let me know what you want for it. Thank you
12-03-2021, 12:17 PM | #14 |
KaBoom1701
You can run JRE no tune package found here.
https://jannettyracing.com/collectio...015-camaro-zl1 But you'll end up running the tune package after a while... its just too much fun. https://jannettyracing.com/products/...015-camaro-zl1 And then realized your missing out on even more fun with their 125rwhp package! Lol. It's kinda how this mod think goes. https://jannettyracing.com/products/...015-camaro-zl1
Mods:
