Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 12-03-2021, 12:33 PM   #1
PFYC
PFYC's Avatar
Drives: Yes
Eibach 38143.880 Pro Plus Spring and Sway Bar Suspension Kit Camaro V6
Product Description
If you love a tight handling Camaro, the Eibach Pro-Plus Performance Handling Package delivers. Eibach Pro-Plus packages include their legendary Eibach Pro-Kit springs along with matching Anti-Roll Kit sway bars. The Eibach Pro-Kit lowers your car's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. Add the Eibach Anti Roll Kit sway bars.with increased roll stiffness, compared to stock bars.and you get pure, balanced-handling perfection. With the Eibach Pro-Plus installed you will immediately experience more-precise turn-in response, improved handling, and enhanced cornering grip.in any performance-driving situation. The Eibach Pro-Plus is designed and tested to work well with either factory or aftermarket performance dampers.
Pro-Kit springs lower the vehicle's center of gravity, reducing body roll in the turns, dive under braking, squat during acceleration and give the car a more solid secure feel at all times. Pro-Kit Springs also minimize the ugly fender gap that makes a car look "lifted".
The included Anti-Roll Kit further reduces body roll and allows fine-tuning of your vehicle's suspension. The goal is neutral, predictable handling. Cold-formed from high strength aircraft grade steel, the anti-roll bars are carefully designed to fit your vehicle without modification.
Increase cornering grip and turn-in response
Shorten stopping distance and increase cornering speeds while maintaining ride quality
Reduce fender-to-wheel gap Lowers V6 Camaro 1.0" Front & 1.3" Rear
Performance Springs and Sway Bars = Superior Handling for the Serious Enthusiast
Precise Turn-in Response, Improved Handling and Enhanced Cornering Grip.in any Performance Driving Situation
Stop Quicker, Corner Faster and get better MPG (up to 12% better)
Simple Bolt-On, With No Modifications: Just Install, Set the Alignment and Carve
Application: 2010-2013 Chevrolet Camaro 3.6L
PFYC is offline   Reply With Quote
Old 10-28-2022, 03:14 AM   #2
PFYC
PFYC's Avatar
Drives: Yes
Thank You for shopping at https://www.pfyc.com/CA4005.html
