12-03-2021, 10:01 PM | #1 |
Drives: Synergy Camaro, Escape Join Date: Feb 2010
Another stainless works/power post
Long story short I have stainless power catted headers with the three inch performance connectors, instead of the stock connectors. Anybody else in here running these into a 2.5 inch cat-back? And how?
12-04-2021, 01:01 AM | #2 |
Drives: 2013 Chevy Camaro ZL1 Join Date: Feb 2021
Exhaust 3" to 2.5" reducer
12-04-2021, 02:14 AM | #3 |
It don’t come easy.
^^^this
The reducer is right after the cats.
12-04-2021, 07:28 AM | #4 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
The reducers come with the kit if you order the right one.
12-04-2021, 08:46 AM | #5 |
Tri-County Camaro SWFL
If you bought the system used i believe Vibrant makes this part as well
12-04-2021, 09:04 AM | #6 |
I wasn’t aware they had two different versions and the vendor didn’t tell me or ask. So I ended up with the 3 in connection pipe. I’m assuming the reducer slips onto the back end of the 3 inch cat to the 2.5 exhaust pipe? Any certain length I would need?
12-04-2021, 09:17 AM | #7 |
It don’t come easy.
Correct. I believe it is a standardized size on the length. I’m guessing if you order from Stainless it will be one size.
12-04-2021, 09:22 AM | #8 |
I actually have a pair if you need them.
12-04-2021, 09:52 AM | #9 |
Send me a pm when you get a chance please.
12-04-2021, 07:20 PM | #10 |
12-04-2021, 07:53 PM | #11 |
I'm fairly certain you can get a set off of Vibrant Performance
12-04-2021, 07:59 PM | #12 |
I got them with my headers originally.
12-05-2021, 08:46 AM | #13 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Call Stainless works, If you don't get the pair above they are good people to deal with. The Headers are the same they just ship out a different adapter depending on the kit you order. I wasn't sure at first and I called them and they explained the differences.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
12-05-2021, 08:49 AM | #14 |
This, I got mine with my headers when we ordered them. Stainless Power/Stainless Works.. If you don't get the ones Larry has...
