12-11-2021, 05:28 AM | #1 |
Drives: 2011 camaro RS, BMW e90 Join Date: May 2016
6th gen 6SS 1LE 6 piston and ZL1 1LE rear set up on 5th gen
I completed my project recently and thought I would share. I managed to order 6th gen SS 1LE 6 piston caliper which I confirmed will fit our 5th gen set up with no additional mods like the CTS V set up. I’m the rear I used the 4 piston set up off of the ZL1 1LE all that needed to be done is reversing the bleeders and crossover. I could have used the CTSV set up and kept my SS calipers, but I wanted the torch red factory painted set up from the 6th gen. I couldn’t find any paint I liked and wanted the OEM finish. I might be the first that I know of to use the 6th gen parts if anyone else has please post here.
12-12-2021, 07:39 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
But doesn’t the ZLE have bigger rotors than our GEN5’s??
Orange Krush II
12-12-2021, 08:22 PM | #3 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
My 2015 Camaro SS has 14” (355) rotors in front and 14.4” (365) in the rear. Were you able to use the 15.35” (390) front rotors from the 6th gen?
12-13-2021, 06:15 AM | #4 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
He used the 1LE calipers which take the 370mm rotor. The Gen6 ZL1 caliper takes a 390mm rotor. Unless you're talking about the rears
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
12-13-2021, 08:39 AM | #5 |
Instagram: Sangstah
wow thats good to know!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
12-16-2021, 12:43 AM | #6 | |
6th gen ZL1 1LE in the rear |
12-16-2021, 01:58 PM | #7 |
Do rears require bigger rotors or fit the SS rotors.
12-16-2021, 08:21 PM | #8 |
Yeah interested in the rear as well
Orange Krush II
12-16-2021, 10:52 PM | #9 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I can speak for the rear ZL1 caliper as it is basically the same as the Gen5 SS/ZL1 rear caliper. If the Gen5 rear rotor is used, then there is no problem. But the Gen6 rear rotor may be the same also.
The Gen6 SS 1LE front caliper is basically the same as the Gen5 ZL1 caliper. The difference in the system lies with the rotor offset as the Gen6 SS 1LE rotor hat is different. Otherwise any front rotor spec'd for a Gen5 ZL1 is correct.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
