Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Wash/Wax/Detailing and Cosmetic Maintenance Parts
Old 12-13-2021, 12:56 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
GRIOTS GARAGE THE BOSS FOAM CANNON
Meet the ultimate foam delivery system. In mere seconds THE BOSS Foam Cannon can blanket your car in rich, cleansing foam.
This cannon is a new-and-improved design that features stainless steel inside and out... a stainless manifold with stainless internals, even the barrel was upgraded from nylon composite to full stainless billet. We also developed swappable jets to increase foam output in applications using a lower-psi pressure washer. Driven by an electric or gas-powered pressure washer, the cannon's nozzle adjusts to produce a wide spray pattern of up to 40° for efficient coverage or a narrow 0° stream for long-range dispensing on car roofs, trucks, and RVs. Our exclusive Auto-Mix feature is a serious innovation. It saves tons of time because you don't have to remove the reservoir and mix the product by hand... It's a "no measuring, no mess, and no math" proposition, just screw in the bottle of concentrate and the metering tip provides the proper ratio. Built to last, our cannon is made with stainless steel internals that resists chemical-induced corrosion that can cause problems with standard brass manifold designs. Cannon includes Stainless Steel Quick Disconnect Coupler (may not be compatible with all pressure washer make and models) and a 1.1mm primary jet. We also offer extra metering tips and reservoirs for your convenience.
The most innovative foam cannon on the market
Our exclusive Auto-Mix feature perfectly mixes your concentrate
Durable precision-machined stainless steel manifold
Patented, no-leak vented reservoir cap
Includes a Stainless Steel Quick Disconnect Coupler (fits most pressure washer makes and models)
Includes 1.1mm primary jet for lower-psi pressure washers
southerncarparts is offline   Reply With Quote
Old 01-19-2022, 04:03 PM   #2
southerncarparts
Thank You for your orders
Old 04-07-2023, 02:43 AM   #3
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/gri...am-cannon.html
