| View our official forum sponsors list. |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 Corvette Z06 Join Date: Aug 2009
2010-2013 CAMARO EIBACH PRO PLUS V6 SUSPENSION KIT
![]() EIBACK PRO PLUS SUSPENSION KIT FOR THE 2010-2013+ CAMARO V6 If you love a tight handling Camaro, the Eibach PRO-PLUS Performance Handling Package delivers. Eibach PRO-PLUS packages include their legendary Eibach PRO-KIT springs along with matching ANTI-ROLL-KIT sway bars. The Eibach PRO-KIT lowers your car's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. Add the Eibach ANTI-ROLL-KIT sway bars.with increased roll stiffness, compared to stock bars.and you get pure, balanced-handling perfection. With the Eibach PRO-PLUS installed you will immediately experience more-precise turn-in response, improved handling, and enhanced cornering grip.in any performance-driving situation. The Eibach PRO-PLUS is designed and tested to work well with either factory or aftermarket performance dampers Eibach Pro-Plus kits include Eibach's Pro-Kit Spring Set and matching Anti-Roll Kit at a savings of 10% over buying components individually. Eibahk Camaro Pro Plus Suspension Kit Increase cornering grip and turn-in response Shorten stopping distance and increase cornering speeds while maintaining ride quality Reduce fender-to-wheel gap Lowers V6 Camaro 1.0" Front & 1.3" Rear PRO-KIT + ANTI-ROLL-KIT = PRO-PLUS Performance Handling Package. Performance Springs and Sway Bars = Superior Handling for the Serious Enthusiast Precise Turn-in Response, Improved Handling and Enhanced Cornering Grip.in any Performance Driving Situation Stop Quicker, Corner Faster and get better MPG (up to 12% better) Simple Bolt-On, With No Modifi cations: Just Install, Set the Alignment and Carve Excellent Ride Quality Million Mile Warrant Pro-Kit springs lower the vehicle's center of gravity, reducing body roll in the turns, dive under braking, squat during acceleration and give the car a more solid secure feel at all times. Pro-Kit Springs also minimize the ugly fender gap that makes a car look "lifted." The included Anti-Roll Kit further reduces body roll and allows fine-tuning of your vehicle's suspension. The goal is neutral, predictable handling. Cold-formed from high strength aircraft grade steel, the anti-roll bars are carefully designed to fit your vehicle without modification. See the Stock Camaro compared to one equiped with the Eibach Pro Plus Kit.... Last edited by southerncarparts; 10-27-2022 at 04:20 AM. |
Thank You for shopping at https://www.southerncarparts.com/201...-sway-bar.html
