12-18-2021, 04:44 AM | #1 |
Drives: 2016 chevy camaro Join Date: Dec 2021
Has anybody else had problems when you shift from 1st to 2nd gear?
Trying to figure out if im the only Camaro owner that is having hard shifts when I go from 1st to 2nd gear. Are there any solutions for this?
12-18-2021, 06:34 AM | #2 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Mine got hard to shift after a while, especially when cold. Changed the tranny fluid and it was back to being smooth again.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
12-18-2021, 07:50 AM | #3 |
PKG4U
I think my shift issues were more 2-3 only in auto sport. Paddle shifting and tour mode give me zero issues. As do any other gear. When mentioned to dealer they shrugged me off as “they had only seen one 10L90 with burnt clutches” as if that was to convince me my tranny was flawless.. lol
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
12-18-2021, 07:53 AM | #4 |
PKG4U
I think as Sengli pointed out, it takes a good bit of driving to warm up the a10. I’ve started to speculate that I never drive my car enough distance, I would say it takes about 20-25 miles of driving AFTER a warm up cycle for my trans temp to even hit 125-135 this time of year. But I don’t drive unless it’s 45* or warmer
12-18-2021, 08:53 AM | #5 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Assuming the A8 (not the A10 because your sig says you have a 2016 Camaro), it did receive a service bulletin about the first shift after a cold start, see below. Also make sure you have the latest transmission fluid that introduced in Jan 2019 to prevent transmission shudder, the service bulletin for that issue is 18-NA-355, flushing the A8 with the new fluid is a warranty service.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
12-18-2021, 08:56 AM | #6 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
The 10L80 is a different animal (and is actually what you have).
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
12-18-2021, 08:59 AM | #7 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
If you’re talking about the Auto 8 Speed (A8) then yes I’ve had it. It took some tuning from the dealer to fix it.
12-18-2021, 10:23 AM | #8 |
Drives: 2017 2SS A8, 2018 Macan GTS Join Date: Sep 2017
This is a known issue with the A8 that has been extensively covered in this forum. I never bothered to have the dealer "Tune it out" because the hard 1st to 2nd shift only happens when the trans is cold. And this hard shift, for the most part, can be avoided by being gentle on the accelerator pedal easing up right after ist gear engages.
The A8 is a track-ready heavy-duty transmission. It's a brute and it can be temperamental at times. Very much like 1970s muscle car automatics is what the A8 reminds me of. That old muscle car feel in a modern platform. |
12-18-2021, 11:44 AM | #9 |
I have an A8. I had the 3 flushes done and had to get a new catalytic converter on my car over the past 2 years because of the shudder problem but I noticed the shudder more in the higher gears. Im wondering if this hard shift from 1st to 2nd has to do with that still or if this a whole new problem now. Has anybody gotten the catalytic converter installed and still had problems later on with the shudder problem?
12-18-2021, 11:49 AM | #10 | |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
12-18-2021, 11:51 AM | #11 |
So ease up right before 1st gear goes into 2nd gear or ease up when I go from 0-5 mph? I usually feel it shift when I hit about 10 mph.
12-18-2021, 11:54 AM | #12 |
GM covered the catalytic converter under warranty but I still had to pay the deductible of $100 dollars I think it was. It was actually a GM dealer that recommended the catalytic converter to me if the three flushes didnt work to solve the shudder problem.
12-18-2021, 11:57 AM | #13 | |
12-18-2021, 12:53 PM | #14 |
Drives: 2021 Camaro ZL1 Join Date: Jan 2016
Guessing OP is actually talking about the torque converter being replaced...
Sent from my SM-G991U using Tapatalk
ZL1 Coupe, Wild Cherry Tintcoat, Black Metallic Center Stripe, A10, Red Knee Pads, Red Seatbelts, Nav. Ordered 12/12/2020, Built 1/14/2021, Arrived at Dealership 2/23/2021, Took Delivery 2/27/2021.
