Old 12-21-2021, 09:55 PM   #1
Blubird68
Drives: 1993 z28/2010 2SS
Wiring question
So I have two autometer gauges I’m trying to wire up. I need 4 power sources, two for lights and two for the gauges itself. I did the add a circuit tap but these fuse boxes are pretty tight, so I’m not sure what my options are. Could I use the one lead to go to another fuse block ? Or would that be drawing too much power ? I’d like to do it as clean and as proper as I can. I’ve added circuits before in my old Camaro but I’m not sure about the newer ones. I’d like it to be on only when the key is on
Blubird68 is offline   Reply With Quote
Old 02-17-2022, 10:51 AM   #2
2010ABM2SS
2010ABM2SS's Avatar
Drives: 2010 2SS Camaro
If you’re comfortable adding an additional power distribution block that would be a good way to attach your accessories and not tap into all of the original wiring.
2010ABM2SS is offline   Reply With Quote
