![]() Drives: 2013 Camaro ZL1 Conv. Join Date: Apr 2016
Supercharger replacement question
Can anyone here tell me if the supercharger replacement, part number 12670278 has the upgraded solid isolator in it?
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
my replaced sc had the new spring in it. take your belt off and spin the hub back and forth if you feel the spring bounce, then no
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
![]() Drives: 2012 Camaro ZL1 Join Date: Aug 2020
No, mine was replaced with that partnumber march 2020
It had this pringloaded isolator packed with grease when i opened it in december Ole Kristian
2012 ZL1 #428
![]() Drives: 2013 ZL1 Join Date: May 2019
When I had mine replaced 2 years ago, it was replaced with a spring-loaded isolator. I immediately the snout off when I got home and changed it. I asked the dealer to change it and they wouldn't.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
IIRC, the original coupler was spring-loaded and not greased.
Eaton then changed the coupler to a solid one after all the complaints. Then later on Eaton changed back to a spring loaded version that was packed with grease to help deaden the sound. No I have no dates for each change. The coupler was spring-loaded to absorb some of the gear chatter caused by the lobes as they spin up and down. |
#6 |
![]() Drives: 2014 ZL1 Join Date: Jun 2009
No. GM in their infinite wisdom will replace your blower with another spring isolator.
Option 1: Sweet talk the tech at the dealer to put in a new solid isolator. Option 2: Have the dealer put in a blower with shitty isolator and change it yourself when you get home. It's not difficult. I did it in less than 3 hours by myself. Of note, I've read most guys will get way fewer miles out of the blower/spring isolator after replacement than they did with the factory blower/spring isolator. My point is that it will happen again but sooner with the new spring isolator.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
#7 |
KaBoom1701
Mods:
#8 | |
#9 |
Not sure of now, but in the early days of the SC coupler failures, the entire was replaced as it was a single replaceable unit made by and sent back to Eaton as they made the unit.
Also, the original TSB notice for the 'rattle' issues, If you had already replaced the coupler, GM would reimburse you for the cost. Again, no idea if that offer is still available. |
#10 | |
The most difficult part is getting the back 4 bolts of the SC lid because they are tucked way back under the cowl. However, you could drill holes for easier access (the plastic shroud covers them back up). Don't over torque the blower bolts. That happens a lot because the manual calls for the torque specs in in/lbs not ft/lbs.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Only the first 1.5 years were replaced with the solid isolator. Basically the price for GM was much higher. So they made the decision to just pack the hell out of the spring with grease. I had mine done in 2012, when the TSB first came out so mine is solid.
#12 | |
#13 | |
#14 |
No. It's just black RTV between the snout and blower body. You could replace the gasket at the throttle body but I reused mine with no issues.
