![]() Drives: 2014 Camaro SS L99 Join Date: Nov 2017
FS: kooks long tubes, High flow/off road cats, Borla Attk cutback
Selling my full exhaust setup, my 416 stroker is almost done and I'm upgrading to 2 inch headers and 3 inch exhaust.
KOOKS LONG TUBE HEADERS 1-7/8 HAS EXTRA BUNG WELDED INTO COLLECTOR, I used it for wide band/AFR. probably has about 4k miles. 2010-2015 Gen 5 $900 (will ship for $50 extra) KOOKS HI-Flow CATS Around 4k Miles $300 KOOKS OFF ROAD CONNECTION PIPES AROUND 2K MILES $120 BORLA ATTK CAT BACK EXHAUST 2010-2013 SS model, but will fit 2014-2015's Around 5k miles. Will not ship, Located in Wayland MI, 49344 $840 PHOTOS: https://flic.kr/s/aHBqjzxm2Z
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
![]() Drives: 2013 Chevrolet Camaro 2SS/RS Join Date: Jan 2022
Are the off road connection pipes the 3" X 2-1/2" for oem connections?
