Old 01-05-2022, 02:23 PM   #1
Rockit_z28
www.1baddogracing.com
Drives: 2010 IOM 2SS/RS Auto
Forgestar F14 Recommended Tire Size
Hi -
I am looking to run the following wheels on my son's car and wanted recommendations on the biggest tire sizes for a stock suspension 2010 Camaro.
Forgestar F14- 5x120 - 20x9 (offset 35) and 20x10.5 (offset 40)
Thank you
Rockit_z28 is offline   Reply With Quote
Old 01-05-2022, 03:29 PM   #2
SaReNi
Drives: 2012 SS
offset will determine the size that will fit.
2012 Camaro SS
SaReNi is offline   Reply With Quote
Old 01-05-2022, 03:32 PM   #3
Rockit_z28
Thank you. I added it above.
Old 01-07-2022, 09:28 AM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Well I'm assuming for "stock suspension" you are not lowered either? The 20x9 front I wouldn't go any wider than a 275/40 or 275/35, the 275/35 will give you a bit lower stance than the 40, on the rear you can run either a 305/35 or the wider 315/35 which is what I did on my 20x10.5's I used to have. I even ran the 315/35's on my 10.0 wides I had for 7 years with no issues.
Old 01-07-2022, 11:53 AM   #5
SaReNi
Drives: 2012 SS
again, depends on the offset. some people have clearance issues on the inside with 315's.
2012 Camaro SS
Old 01-07-2022, 12:08 PM   #6
SaReNi
Drives: 2012 SS
https://www.motortrend.com/how-to/16...th-gen-camaro/
2012 Camaro SS
Old 01-07-2022, 04:58 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have had +25,+30,+43 all on the rears with the 315's no problem on 10.0-10.5 wide wheels. Yes the offset will determine, plus the style of the wheel. If you purchase wheels made for the year Camaro you have, you won't have an issue as they are "fitted" for the car.
Old 01-07-2022, 05:00 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Nice info!!
