Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > ZL1 Engine, Exhaust, and Bolt-Ons
Old 01-13-2022, 12:30 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
2010-2015 Camaro /Camaro O2 Sensor Extension
Corvette C6 and 2010+ Camaro O2 Sensor Extension
When installing aftermarket headers and cat-back systems in your vehicle, the oxygen sensor is frequently relocated, usually far enough away from the original wiring location that the connector cant be re-installed. You cannot cut and splice oxygen sensor wiring since this can permanently damage the sensor and considerably reduce the accuracy of the signal. These extensions are "Plug-And-Play" and utilize OEM connectors, terminals and seals with OEM wiring to maintain precisely accurate signals and safely extend the wiring connections.
"FREE SHIPPING" NOTE: "NO COUPON CODES CAN BE USED ON THIS PRODUCT, IF A CODE IS USED, THE ORDER WILL BE CANCELED"
RPIDon is offline   Reply With Quote
Old 04-12-2023, 07:39 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank You for shopping at https://www.rpidesigns.com/shop/item.aspx?itemid=3060
