Old 01-14-2022, 11:37 PM   #1
Brandonlin152
Drives: Chevy Camaro SS
*HELP* 416 LS9 2010 Camaro SS *Service Stabilitrack Issues*
Hi Everyone,
I am new to the group. I have a 2010 Camaro 1SS 6MT with forged internals, 416 stroker kit, and LS9 blower on top.
Issue: When the car moves I get Service stabilitrack with all traction lights on. Sometimes I also get the BRAKE and ABS light on with them as well. It is usually a variation of 3 different lights that stay on at one time then go away.
I have been trying to diagnose my issue with stabilitrack and ABS for about a year now. I have replaced the hub and sensor and get proper readings on those from the scan tool. I also know it is not related to the engine. On the live data with the scan tool the ABS Pump Motor always reads 0V. The many codes I get are listed below and can also be found in the images. Thanks in advance any help would be great! I am desperate
I am thinking it is a problem with the ABS Pump and should be replaced or it is a ground somewhere. (Although I have looked so hard)
U0121 Lost communications with electronic brake control module (EBCM)
C0035 Left front wheel speed sensor circuit (even after replacing hub and sensor)
C0110 Pump motor circuit
C0242 Powertrain control module indicated traction control
C0245 Wheel speed sensor frequency
C0710-5A Steering position signal - Not plausible
U0125 Lost communications with multi-axis acceleration sensor module
U0126 Lost communications with multi-axis acceleration sensor module
Thanks!!!
Brandonlin152 is offline   Reply With Quote
Old 01-14-2022, 11:59 PM   #2
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
I’ve found that “loss of communication” is a good place to begin basic systematic troubleshooting when encountering such issues.
To find what a problem is you must find everything the problem isn’t.
ADVMax is offline   Reply With Quote
Old 01-15-2022, 12:08 AM   #3
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Throwing a bunch of codes is often bad battery or bad grounds. With the motor being swapped I'd look close at what ground connections should be clean and in place and didn't get lost during the swap out. There' s a few good diagrams on it here, I know the search function on here sucks, better to use google.
copy/paste this into google site:camaro5.com engine ground connections
https://www.camaro5.com/forums/showthread.php?t=221700
https://www.camaro5.com/forums/showt...=399658&page=4
https://www.camaro5.com/forums/showthread.php?t=511228
I'm thinking along the lines of the post that is above me, before I finished searching to post this.
Checking grounds and general cable plug-ins to make sure pins aren't pushed back or bent or a cable got mashed during the work. I'd do that first before trying to chase a single trouble code only, because of how many you got at once.
silversleeper is offline   Reply With Quote
Old 01-15-2022, 12:30 AM   #4
ADVMax
Sporting Foole
ADVMax's Avatar
yes
Old 01-15-2022, 09:15 AM   #5
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Originally Posted by Brandonlin152 View Post
Hi Everyone,
Thanks!!!
I've seen this many times. It's usually the ebcm but I always sell the bpmv with it. Also looks like your going to need to replace the steering wheel angle sensor as well. The angle sensor is plug and play but the ebcm is not, it will need programming.
NOT A 45 is offline   Reply With Quote
Old 01-15-2022, 09:22 AM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Before replacing modules and sensors, look at wires in the engine compartment. Pinched wires or insulation melted from proximity to headers (if have them) recur in this forum.
Rock-It Man is offline   Reply With Quote
Old 01-15-2022, 10:18 AM   #7
NOT A 45
NOT A 45's Avatar
That's great advice for any electrical problem, but in this instance you have to fully understand what the scan tool is telling you. Although all the codes set are history and not current, only one of the codes requested the light to come on. C0110 is where you need to start the diagnosis. The 2 digits following the code have meaning as well, C0110-00 means there is either a short to the pump motor or there is a open circuit/high resistance to the pump motor. The power to the pump motor comes from the relay in the ebcm, and the ebcm mounts directly to the bpmv.....there is no wiring between the 2. Armed with this knowledge we now know there are only a few possibilities.
1. There's a open or short in the pump motor windings
2. The relay in the ebcm is faulty
3. There's a problem with the power or ground going to the ebcm
4. The circuitry in the ebcm is faulty.
After verifying the integrity of the power and ground to the ebcm (which I would expect a slew of other codes to be set if this were a problem) it can only be the module or the bpmv. The diagnostic from GM actually directs you to replace the bpmv first and if the code returns replace the ebcm! Try selling that to a customer! $2500 in parts plus labor.
Because the ebcm mounts directly to the bpmv there is no way to tell which part is faulty. My advice is to start with the ebcm since you have to remove it first anyway and you don't have to fool with the brake lines. But don't be surprised if you still have to replace the bpmv as well. I've been down this road too many times that's why I sell both pieces from the start.
Old 01-15-2022, 11:48 AM   #8
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
I had C6 Vette, that it had a problem. I had to have the Yay sensor replaced under warranty.
sscamaro is offline   Reply With Quote
Old 01-15-2022, 12:33 PM   #9
silversleeper
Big Crow
Drives: '13 ZL1
That is good information. Do you happen to know off the top of your head if any junkyard 5th gen computer modules will work or if they are different?
Old 01-15-2022, 02:17 PM   #10
NOT A 45
NOT A 45's Avatar
If its the same part number you should be able to overwrite the program. The newer modules like 16 up you cannot
Old 01-15-2022, 07:14 PM   #11
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Nice info! I saw you said you work at a dealer near DC? Care if I ask which one? I worked in a couple body shops in northern Va and was in and out of a lot of the area dealers running parts and such. I grew up in the area and my family is mostly all still there.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 01-16-2022, 01:30 PM   #12
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Excellent information!! You rock!
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 01-16-2022, 06:35 PM   #13
NOT A 45
NOT A 45's Avatar
I’m the corvette tech at Ourisman Chevrolet of Bowie however I’ve been doing this for 38 years so I’ve been around the block...lol Lotaburger is my spot every time I’m in Vegas btw!
Old 01-16-2022, 07:47 PM   #14
Brandonlin152
Thank you, I will test this during the week! Can I buy a used ebcm on ebay or not a good idea?
abs, abs help, ls9, service stabilitrack, traction control
