![]() Drives: 2010 Chevrolet Camaro 2LT RS Join Date: Jan 2022
PFADT Race Suspension rear strut replacement?
My 2010 2LT RS came with a "Full PFADT race suspension" and since that company is no more I can't really find documentation of what, exactly a PFADT "full race suspension" is. It's got Pfadt sway bars and springs for sure. I just discovered a broken left rear sway bar link and a spring not centered on the strut. The spring appeared to have been rubbing on the end link. Did the broken end link cause the rubbing or did the rubbing cause the link to fail? Replacing the link is easy enough...could I reuse the springs with new struts to maintain ride height? Are there appropriate replacement strut assemblies? F it and replace all 4 with new coilovers? I don't know...Thoughts?
AFE Power bought Pfadt several years ago. Might try looking there or contacting them.
https://afepower.com/vehicle-platfor...c=64&is_ajax=1
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
Good info, thanks.
![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
If you have version 1 of the Pfadt coil overs you are SOL. AFE will not rebuild them. Even if they did, last time I checked a few years ago they were $250 a corner to have rebuilt. I am about to replace the Pfadt fronts on my SS with KWs. Already did the rears since all 4 have been leaking.
I installed a pair of Moog end links in place of the OEM's that seemed comically small on the beefy Pfadt rear sway bar. All good so far.
