Geoff
Drives: 2022 SS 1LE Join Date: May 2013
SDPC LS7 Dry to Wet Sump Conversion Spacer
Spacer that allows you to use an LS dry sump crank in a wet sump engine. Free for pick up in Houston area or you pay shipping.
From Scoggin Dickey website: Installs on the long snout of the dry sump LS7 crankshaft to provide the correct offset spacing for using a standard LS oil pump, the stock style wet sump front cover and stock front accessory drive components. When using this spacer, make sure to use the correct balancer that will matches the alignment of the rest of your front accessory drive components. Installs between the harmonic balancer and the crankshaft bolt.
