Old 01-19-2022, 01:24 PM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Procharger P1SC-1 belt slip
My buddy has a Redline-Motorsports 416, P1SC-1, E85, Exhaust, Holley Hi-Ram.
We hit the local Dyno-Jet the other day, and he kept shredding/throwing belts.
I'm not sure of his pulley combo, but I know it's near max rpm for the little P1.
His first pull it made 750whp and only had 6 ribs on the 8 rib belt.
Second run it threw the belt, but was on course to make 800. On his tuners dyno, he made 830whp.
He has the standard type Procharger tensioner that pushes down on the horizontal portion of the belt. The belt he had on was really hard to get back on. We had to get it started on the SC pulley, and bump the starter to spin it on fully. Then he cranked it down with the tensioner.
In my opinion, his belt is too short, and his tensioner is set too tight.
Is this a common issue for Prochargers? What are his options?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 01-19-2022, 03:43 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
It happened on Derek Bieri's (Vice Grip Garage) Independence Chevelle at Freedom Works burnout contest.
Old 01-20-2022, 09:35 AM   #3
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Just go 12 rib, buy the ATI damper and 12 rib kit from Brutespeed (call and talk to Bob) I am maxing out / slightly over-spinning a F1-A procharger with a 12 rib ZERO belt slip.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 01-21-2022, 06:16 AM   #4
eLeSthree
Thanks, Bildo. He called Bob. Apparently he's been running a belt thats way too short. He's gonna try the right sized belt and put the tensioner in the right position, and if that doesn't work he'll go 12 rib. Not a bad price for that kit.
1158whp 1017wtq.
630whp 658wtq
Old 01-21-2022, 08:44 AM   #5
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
This. I had an 8 rib setup on a procharged firebird I had built years ago and it was plagued with constant belt slipping issues. Was running 12#s, but it slipped constantly. Their tensioner that came with that system sucked ass
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
