Old 01-20-2022, 06:18 PM   #1
Minority1
Misdeal
Minority1's Avatar
Drives: 2011 Chevy Camaro LT
2011 Camaro v6 P0089 and misfire codes
I have multiple misfire codes P0301, P0303, and P0305 and also have a P0089 code. Can the P0089 code be causing the misfires codes?
DTCFRZF P0300
FUELSYS1 OL
FUELSYS2 OL ?
LOAD_PCT(%) 74.9
ECT (*F) 51
SHRTFT1 (%) 0.0
LONGFT1 (%) -0.8
SHRTFT2 (%) 0.0
LONGFT2 (%) 5.5
RPM (rpm) 1049 ?
VSS(mph) 0
SPARKADV ( ) 0
IAT (*F) 60
MAF (lb/s) 0.05
TP(%) 32.9
RUNTM(sec) 1
FRP(psi) 1240.0 ?
EVAP_PCT(%) 0.0
FLI(%) 94.9
BARO(psi) 14.1
VPWR (V) 13.146
LOAD_ABS(%) 59.2
EQ_RAT 0.997
TP_R(%) 19.2 ?
AAT(*F) 51
TP_B(%) 32.9
APP_D(%) 19.6
APP_E(%) 20.4
TAC_PCT(%) 28.2
LGSO2FT1(%) 0.0
LGSO2FT2(%) -3.9 ?
Last edited by Minority1; 01-20-2022 at 07:22 PM. Reason: I added my DTC freeze frame
Minority1 is offline   Reply With Quote
Old 01-20-2022, 07:36 PM   #2
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
DTCFRZF P0300
FUELSYS1 OL
FUELSYS2 OL ?
LOAD_PCT(%) 74.9
ECT (*F) 51
SHRTFT1 (%) 0.0
LONGFT1 (%) -0.8
SHRTFT2 (%) 0.0
LONGFT2 (%) 5.5
RPM (rpm) 1049 ?
VSS(mph) 0
SPARKADV ( ) 0
IAT (*F) 60
MAF (lb/s) 0.05
TP(%) 32.9
RUNTM(sec) 1
FRP(psi) 1240.0 ?
EVAP_PCT(%) 0.0
FLI(%) 94.9
BARO(psi) 14.1
VPWR (V) 13.146
LOAD_ABS(%) 59.2
EQ_RAT 0.997
TP_R(%) 19.2 ?
AAT(*F) 51
TP_B(%) 32.9
APP_D(%) 19.6
APP_E(%) 20.4
TAC_PCT(%) 28.2
LGSO2FT1(%) 0.0
LGSO2FT2(%) -3.9 ?
Without having the vehicle in front of me and not being able to find my crystal ball.....I’d say your high pressure fuel pump is taking a shit.
NOT A 45 is offline   Reply With Quote
Old 01-20-2022, 08:01 PM   #3
Minority1
Misdeal
Minority1's Avatar
Aight ill look into that.
misfire engine, p0089, p0301, p0303, p0305
