01-20-2022, 07:15 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
Transmission fluid drenched
On the passenger side there is transmission fluid covering the bottom from the frame and from the backside, can anyone tell me if this was from the over fill drain line that hangs to the side that sprayed all of it out towards the back ? I turn the car on and I don't see it leaking anywhere what could it have been?
01-20-2022, 07:22 PM | #2 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
My advice, get that hose connected properly then warm the engine to operating temperature. That plug on the pan isn’t a drain plug, it’s how you set the fluid level. Once hot, remove the plug and wait for the fluid to stop coming out. Now your trans is at the proper level. Put the plug back in and you should be good |
01-20-2022, 07:46 PM | #3 |
It's a remanufactured transmission was put in a couple months ago and where would I find this other line that's connects to that hose hanging down from in back of the engine?
01-20-2022, 07:58 PM | #4 |
All I found was this
01-20-2022, 08:12 PM | #5 |
Without seeing the car I’m thinking #3 is what’s hanging on the last pic you sent. If so it should be routed up towards the back of the engine. Even Without anything connected to the vent on the trans if the fluid level is filled correctly and there is nothing slipping in the trans or no condition that’s causing it to overheat no fluid should come from the vent.
01-20-2022, 09:45 PM | #6 |
Found this piece that goes into the transmission disconnected I'm just trying to find the hole that it goes into it blind
01-21-2022, 06:15 AM | #7 |
That's the vent tube. It's pressed into a hole on the top of the transmission near where the bell housing bolts to the trans case. You probably don't have enough room to reinstall that with the trans in the car. The illustration you posted shows where it goes in the trans
01-21-2022, 09:56 AM | #8 |
You were right about it being overfilled but the only thing I can think of when it started pouring out like that the temperature was at 183 deg in stop and go traffic
01-21-2022, 02:37 PM | #9 |
Drives: 1969 camaro and 2010 camaro Join Date: Jul 2009
That looks like coolant. I would check the heater hose fittings just above on the firewall. The quick connect fittings are notorious for leaking!
01-21-2022, 02:50 PM | #10 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Looks like transmission fluid (reddish color). The orange looks like paint marker as someone checked bolts.
01-21-2022, 04:44 PM | #11 |
183 is not bad, that's kind of normal for a stock tranny/converter.
01-22-2022, 07:24 AM | #12 |
[QUOTE=1JEWLDSSRS;11123703]183 is not bad, that's kind of normal for a stock tranny/converter.[/QUOTE
Your coolant temp and trans temp should closely mirror each other. Think about it....they're both cooled in the same radiator! |
01-22-2022, 10:15 AM | #13 |
[QUOTE=NOT A 45;11123903]Stock yes, on mine with the big converter and an aftermarket tranny cooler, cruising, my trans runs cooler than the engine coolant does, about 158-160 except when I'm running her hard.
01-22-2022, 02:13 PM | #14 |
Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
man...45 is a Savant...just saying..
