![]() Drives: 2010 camaro Join Date: Mar 2020
Help please! Need a measurement
I need a measurement from the pinch welds under the car. The pinch welds I'm talkin about are the ones on the body starting in the front at the fender opening running to where the rear wheel opening is under the car on the body . The measurement should be taking as far back as possible and taken from pinch weld to pinch weld (side to side) I had the measurement but somehow it got wiped off the body of the car. I desperately need this measurement anybody that helps I would be greatly appreciative thanks to everyone for the help
![]() ![]() ![]() ![]() ![]() Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi Join Date: Apr 2009
I can tomorrow.
Do you just need the front and back side to side measurement???
Yea, I just went out to measure for you and I can'r get under my Camaro, she is too low, plus my ZL1 rockers kind of block the area since they are more aggressive than the stock SS rockers. Sorry bro.
Shit. Forgot. I will try in the morning.
#6 |
![]() Drives: 2015 zl1 m6 Join Date: Jan 2020
I measured 60 3/4” I have a zl1 though if that is different
That’s outside to outside of pinch weld . |
#7 |
Set a reminder today. Sorry for the delay.
See photos, but the tape did have to stretch below the exhaust. A quick CAD layout in Solidworks puts the dim closer to 60.375" outside to outside. I ballparked the distance between the exhaust at 16", because I can't get under the car. If you have a better dimension for that I can tweak the layout.
2013 2SS |
