Old 01-21-2022, 12:46 PM   #1
shu92870
shu92870's Avatar
Drives: 2014 Camaro SS 1LE
Stock Brembo Seal/Boot Kit
Anyone know the OEM numbers for the dust boot and seal rebuild kit?
Mine are melted pretty good.
Figure time to replace for the new track season.
Any idea how difficult they may be to replace?
Thanks
SHU
shu92870 is offline   Reply With Quote
Old 01-21-2022, 07:38 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Try Rock Auto they should have them.
Orange Krush II
Old 01-24-2022, 03:07 PM   #3
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
They are easy to replace. The hard part is pulling the caliper off and bleeding after. You could replace the dust shields (no bleed) and not the seals on the pistons, but if you got them that hot I would do both. I have removed seals and shields twice. Get yourself a pick and o-ring set, makes the job a lot easier. I removed the calipers completely since I was going to replace the brake fluid. Once they are off use an air compressor to push out the pistons. Put a block of wood between the pistons and carefully hit the air pressure on the brake line fitting. They will pop out fast so that's the reason to use a block of wood to keep both sides coming out evenly. If only the pistons on one side come out, you will have to push them back in so both sides will move out of the caliper. Plenty of u-tube videos on how to do it which will show you better than I can write an explanation.
bannonm is offline   Reply With Quote
Old 01-28-2022, 03:50 PM   #4
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
For $408 each, upgrading to brand new C7 Z06 rotors was the way I went. Total bill was larger obviously as I needed new pads and rotors at the same time, but if you need those already it might be something to look into.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 01-30-2022, 01:55 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Go this route
This is the way.
Orange Krush II
Old 02-01-2022, 07:23 PM   #6
shu92870
shu92870's Avatar
Yeah I didn’t have the funds to upgrade the fronts to the 6 piston. Thats pretty expensive.
I opted for seals and new Raybestos st43 pads. Which are awesome but i have problem with them cutting into the ABS too much.
Old 02-02-2022, 11:14 AM   #7
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
Its not as expensive as you think if you find the parts yourself.
I ordered most on the parts individually off RockAuto for about $1300 using the list Nick S. wrote up on the 3rd post in here:
https://www.camaro5.com/forums/showthread.php?p=8744227
As for making the most with the stock brakes, I have heard Raybestos ST43 is the way to go.
I ordered a set for my 6-piston setup but they are on "Indefinite backorder".
Also, one thing you can add to your setup is some titanium spacer plates.
https://knsbrakes.com/c/car-series/5...itanium+Shims+
They help keep heat off the calipers and cooking your boots and fluid.
So your fresh boot kit will last longer!
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 02-25-2022, 01:28 PM   #8
shu92870
shu92870's Avatar
Yeah I bought the ST43.
That are a HUGE improvement for the track.
But now I’m consistently hitting the ABS. I gotta fine tune my braking.
Old 02-26-2022, 01:27 PM   #9
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I found myself getting into Ice Mode with them. Definitely had to adjust my approach to braking.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
