Old 01-23-2022, 04:51 PM   #1
Jonathan26
Drives: 2010 Camaro SS
Unhappy HELP with diagnosing Bad chatter/Grinding car wont move only accelerate
So I let my friend drive my car and I let him give it a good rip and well the car stopped grabbing and it would just rev up without moving, at first I thought it was the clutch bc well im spraying the car with a 100 shot and the clutch was already slipping when nitrous was activated but not when the car was on N/A power. So new clutch and slave is in and the car is still making the same noise when the car first broke now im lost. I check diff fluid and trans they both came out clean of no metal shaving or nothing. I lifted the car and both wheels turn but initially only the passenger side was turning at first and left wheels was completely stopped until i put it in reverse than both wheels started turning. Than back in first gear and both wheels turn now. Now when the car is lifted in the air it doesnt make the noise. When the drivetrain is under no weight so im hoping it isnt the transmission or something it makes the noise near the middle of the car where the shifter sits right underneath I check driveshaft bolts and nothing all good im always replacing the bolts. So if anybody has any advice please leave a response and I’ll go and check it out see. Just hoping i don’t have to drop trans again… yes it reads MPH it reads 5-6 mph when clutch is fully released and grinding bad. At first it wouldn’t let me go into any gear after putting clutch together and trans but I messed with the gears like individually than all gears went in with ease. Was like a wall blocking me. Before new clutch was installed the car did the same movement it does now it moves forward until it has to move under weight
Last edited by Jonathan26; 01-23-2022 at 05:13 PM. Reason: Forgot to add more details
Jonathan26 is offline   Reply With Quote
Old 01-23-2022, 05:18 PM   #2
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Sounds like transmission broken.
silversleeper is offline   Reply With Quote
Old 01-24-2022, 07:13 AM   #3
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Did you blow a Tranny? Hahaha
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 01-24-2022, 08:09 AM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Very early 2010 M6 cars had a weak output shaft prone to snapping. It was a manufacturing defect, i.e. bad batch of shafts.
Old 01-24-2022, 08:48 AM   #5
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
I concur.....Vettes did the same thing, but their output shaft was 3x longer.
NOT A 45 is offline   Reply With Quote
Old 01-24-2022, 08:49 AM   #6
Vicster
Drives: 13' ZL1
Sounds like...
Hello,
You may have shredded the giubo coupling. It is what is used in place of a U-joint.
Vicster is offline   Reply With Quote
Old 01-24-2022, 08:53 AM   #7
Jonathan26
Correct me if im wrong but if the output shaft is broken wouldnt the driveshaft not spin? Because it spins just rear tires don’t move
Old 01-24-2022, 08:54 AM   #8
Jonathan26
Originally Posted by Vicster View Post
Hello,
Check those too both coupling and bolts look fine.
Old 01-24-2022, 08:55 AM   #9
Jonathan26
I hope not :/
Old 01-24-2022, 08:56 AM   #10
Jonathan26
Update
Bought some axles imma slap them on today to see if that solves some issues or solves it all.
Old 01-24-2022, 10:26 AM   #11
silversleeper
Big Crow
Drives: '13 ZL1
Gears out of rear differential. But when you said it wouldn't go into gear etc. that's trans. Or tranny or whatever the correct name is now, "They".
Your they and your other is broken.
Could be both trans and diff then.
Or clutch and diff. It's hard for me to figure out by the info given.
Old 01-24-2022, 12:09 PM   #12
NOT A 45
NOT A 45's Avatar
This is too easy.....take your cell phone and put it on video, place it directly under the yoke on the rear diff. Start the car and with the parking brake on let the clutch out in 1st gear. If the yoke spun its in the diff, if it didn't its in the trans.
Old 01-24-2022, 12:13 PM   #13
NOT A 45
NOT A 45's Avatar
My bet is the output shaft.....
Old 01-24-2022, 01:05 PM   #14
CamaroCracka
It could spin but it would have no power, just like a broken axle might turn up in the air, but on the ground, nothing but noise. Just had that with a snapped axle. Good way to tell is put it in the air, put it in gear, and turn the tail shaft flange with a pry bar. I would think you would be able to feel it if it was broken.
If you think it's the diff, disconnect the shaft and spin the yoke.
Inspect the guibos while you are down there.
Edit: or you try 45's cell phone trick. Never did that one.
camaross, drivetrain, help me please, ls3 5thgen, mechanical
