Old 01-11-2010, 06:42 AM   #1
sting808
Drives: 2010 SS RS
Trunk mounted battery replacement
I noticed the trunk mounted battery has a hose leading to the exterior. Is this for gas venting so nothing builds up in the trunk? I don't recall ever having seen a replacement battery with a hose fitting for venting. Wonder if a special battery is needed with this fitting.
Also, the battery area doesn't appear to have a plastic tub or tray to catch battery acid. Depending on what GM says about this, I may need to mod something.
Thinking of putting a JL HD750 series amp in the this area. Will not push the amp so cooling shouldn't be a problem. We'll see what happens to this plan...
sting808 is offline   Reply With Quote
Battery in the trunk Baughman 5th Gen Camaro SS LS LT General Discussions 72 08-21-2010 11:13 AM
Rear Mounted Battery Wacker Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 08-21-2010 09:20 AM
GM To Build Battery Plant Mr. Wyndham General Automotive + Other Cars Discussion 5 01-13-2009 02:03 PM
So the battery is in the trunk...confirmed? 1_2Many 5th Gen Camaro SS LS LT General Discussions 53 12-14-2008 07:52 AM
