Old 01-25-2022, 08:23 PM   #1
Blubird68
Drives: 1993 z28/2010 2SS
Need help lowering oil pan
So I’m trying to get the dreaded bolt for the oil pump on the pickup tube. I unbolted all the oil pan bolts, the 2 going from the bellhousing, the plastic starter shields are off and I only have one bolt left on top for the oil cooler but the pan isn’t moving at all. Even tried tapping it. I can’t figure it out and it’s frustrating me. It’s just crazy to me it’s still being held on with nothing
Blubird68 is offline   Reply With Quote
Old 01-25-2022, 09:53 PM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Not sure about the SS, but the Z has a ton of crap mounted to the pan. It's possible the pan is just sticking to the gasket especially at the front. Both times i dropped the oil pan, I had the alternator out to get to the wiring tray attached to the pan. There were like 2 bolts that I missed because they were tucked above the wiring and lines. Like I said tho, it's a Z. Hopefully an SS guy will chime in here.
FasNuf is offline   Reply With Quote
Old 01-26-2022, 12:06 AM   #3
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
You have to unbolt the starter. There are two 13mm bolts. Once these are out or loose enough, that should release the pan. The starter won’t fall or come out, it will hang in place.
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 01-26-2022, 09:31 PM   #4
Blubird68
I don’t know if I’m doing something wrong or if Goliath built this car. I did unbolt the starter bolts and still nothing.
Old 01-27-2022, 01:28 AM   #5
dma05
dma05's Avatar
I believe the pan has a total of 13 bolts. 11 short ones and 2 long ones. Also make sure to take off the nut AND the stud off of the front driver side of the pan that holds the AC lines and the power line. This one can be tricky.
Best to count all the bolts you loosened to make sure you hit them all. The 2 on the bellhousing would make it 15 bolts.
Allen
2011 Camaro 2SS/RS
Old 01-27-2022, 11:28 AM   #6
xc_SS/RS
Drives: 2010 Camaro SS/RS
I had all of mine loose and still needed to tap it slightly with a deadblow to dislodge it. Recently did the oil pump swap myself, wasnt that bad minus dropping the bolt in the pan lol
Highly recommend keeping rags in the pan, under the bolt until it is tightened down. I accidentally dropped mine in the pan but was able to fish it out with something like this: https://www.homedepot.com/p/Lisle-Mi...6540/207011197
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-27-2022, 08:52 PM   #7
Blubird68
I’ll have to revisit the AC lines and power lines then. I completely removed the oil cooler and thought that would be it. I do have a magnet just in case the bolt does drop. Hopefully I have better luck tomorrow
Old 01-28-2022, 09:02 AM   #8
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
The factory put some rtv at all 4 corners of the pan . Chances are your gonna mangle the oil pan gasket so make sure you get a new one .
Also make sure you put that rtv back on all corners when installing the pan back .
Risingson05 is offline   Reply With Quote
Old 01-29-2022, 07:21 PM   #9
Blubird68
I finally got it to drop, it was stuck on pretty good
