![]() Drives: 2012 Camaro 2ss 45th anniversary Join Date: Nov 2021
Codes? What Do They Mean?
I have these codes that have popped up on my 2012 2ss ls3. I don't know what they could be. I have a warrenty but I am just curious as to what could be causing this. These codes popped up and there is no rpm reading on the dash. It says service stabilitrak and engine power reduced. Also the car grinds going into 2nd when it is cold. Even if I let the car warm up for 10 minutes. Please help here are some pictures of the codes. I put the skip shift eliminator on fyi It is working perfectly.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
If you have the Warranty and not sure I guess I would use it, But the First thing I would try is make sure the battery is good and holding a full charge, Just because it starts car doesn't mean it is not failing. Since you have a few different unrelated codes I would assume an electrical issue, Weak battery , Loose /dirty connection. As far as the grinding I would service the trans if it has not been done in a while and see what happens.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
^^^^ This..When these batteries on these cars start going bad, funky things start happening..
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
My 2010 did a couple of sketchy error posts on the dash and after seeing the recommendation here of just put a battery in it I did.
When I went to pick up my new battery I had them load test what seemed to be an OK battery out of my car. Fell flat on its face before he has the test machine turned on good. At least have your existing battery load tested before digging too deep. |
#5 | |
#6 |
![]() ![]() Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Just had this same code on a Avalanche...sure enough found the battery only had 180 cca!
| Tags |
| codes, grinding, limp mode |
