Old 02-02-2022, 12:42 AM   #1
claudiel19
Drives: Camaro SS 2014
Is this normal engine noise?
Parked in my garage on idle heard these engine noises. Are these normal or anything to worry about? Car runs fine with 48k miles, automatic transmission L99 stock with no baffles and CAI inc intake.
claudiel19 is offline   Reply With Quote
Old 02-02-2022, 12:46 AM   #2
claudiel19
Sound clip video link here:
https://drive.google.com/file/d/1BBe...w?usp=drivesdk
Old 02-03-2022, 12:11 AM   #3
claudiel19
Bump. Anyone?
Old 02-03-2022, 04:05 AM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Well I've never owned an SS. I went from a V6 LFX to a ZL1 but that sounds like a pulley or bearing issue when your AC compressor is cyling. Just a guess though.
Mods:
Old 02-03-2022, 10:14 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I listened to it and it does sound like an idler/tension pulley might be to blame, maybe even the AC clutch going bad..
Old 02-18-2022, 08:47 PM   #6
claudiel19
I took a look again today and see that the harmonic balancer is wobbling a bit. I stuck my hand down to feel the bolt and it was not loose. Did some search through the forums and found some threads saying this is normal in these corvette engines? am I wrong? Anyhow, will take to the dealer to check it as soon as I can. Took it to a mon n pop shop and they quoted me $600 total, not sure if this is a good deal or not.
Old 02-18-2022, 09:05 PM   #7
claudiel19
harmonic balancer video link here:
https://drive.google.com/file/d/1E4N...ew?usp=sharing
Old 02-19-2022, 01:01 AM   #8
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Is the AC on ?
chevy pilot is online now   Reply With Quote
Old 02-19-2022, 09:06 AM   #9
claudiel19
Originally Posted by chevy pilot View Post
Is the AC on ?
AC is not on. Could it be harmonic balancer wobble causing that? See video above
Old 02-19-2022, 10:32 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
One of my friends has this "wobbling" issue with his 2011 Corvette GS, and when I checked with my tune shop who specializes is LS engines, had told me that the "stock" balancers have has an issue of coming apart and causing it to wobble like that. Not saying that is your issue, but we replaced his with a Fluiddamper unit and all is fine now, mine was replaced with a GM performance unit and is good, but I never had a wobble problem. Good luck.
