02-04-2022, 07:31 AM | #1 |
Drives: 2022 Chevy Camaro 2SS Redline Join Date: Dec 2016
Water and moisture in Camaro 2011 2SS Trunk Why?
When it rains I am getting water and moisture inside my trunk. I live in Houston, TX and I know there's levels of humidity. I checked the main trunk seal and it appears to be in overall great condition. The only conclusion I can come to terms with is that the trunk has gaps that do not align up correctly with the rest of the rear body of the car. I know the vehicle once was in a small accident before I purchased it. The title is still clean and clear. I just wish I knew how to pin point this problem. Here's some pictures. What could I do to resolve this issue? Is it the weather stripping at the bottom of the rear window? I wonder where I can start looking?
Closed left side trunk Closed right side trunk Wet inside trunk Wet moisture at the bottom of the trunk |
02-04-2022, 07:40 AM | #2 |
Started#gottalovethatblue
Do you have a sunroof? That’s the number one place that these cars leak from in the trunk typically.
02-04-2022, 07:44 AM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
if you have a sunroof, check the drain hose connections under the package tray.
02-04-2022, 08:07 AM | #4 |
^^^ this is usually always the case with cars with the sunroof!! Good luck..
02-04-2022, 08:44 AM | #5 |
Get in the trunk with a light. Close the trunk and have someone run water from a garden hose over the seams and rear window.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
02-04-2022, 09:14 AM | #6 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
02-04-2022, 09:40 AM | #7 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Sun roof drains are easy to check. Just reach up behind the hinges & feel around for the rubber hose. You will know immediately.
02-04-2022, 11:04 AM | #8 |
Drives: 2010 Camaro 2SS RS L99 Join Date: Jan 2021
I had the same issue before, but it instead of light moisture, there was a lot of water in place of where the battery sits. I never figured out the issue as it never happened again, but it could possibly be the connection with the sunroof or, most likely, trunk issues. Check to see if the weather strips are secured and if still an issue, the misalignment of trunk may need to be situated. Good luck!
Roto-Fab Cold Air Intake, Resonator Delete, Flowmaster Super 10 Mufflers
02-05-2022, 03:07 AM | #9 |
02-05-2022, 03:08 AM | #10 |
02-05-2022, 12:15 PM | #11 | |
02-05-2022, 12:26 PM | #12 | |
02-05-2022, 12:27 PM | #13 |
You all gave me a butch of ideas. Here's some helpful videos for everyone else to learn from.
02-05-2022, 02:14 PM | #14 |
Thanks for posting these, was that your problem?
