Old 02-04-2022, 11:49 AM   #1
Dankmeme
Dankmeme's Avatar
Drives: 2012 Camaro RS 1lt
MRT V2 J-PIPE
So I know this question was probably asked 100 times but anyways..
I have a 2012 Chevy camaro v6 stock with only the MRT V2 on it. At first , i tolerated and dealt with the drone perfectly fine but now that I take long drives back and forth its really becoming a nuisance. I do not have the money to get a remove this and get a different exhaust nor will I go back to my stock mufflers. Instead, i want to do the J pipe fix and was told that if i buy the pipe, the place will do all the work for me. So two questions...
Does anyone have a link to the pipe needed? and what are the correct measurements, i believe the pipes should be cut at around 29 inches and they also said something about "capped or noncapped" so i want to understand what that means. someone please let me know thank you.
Dankmeme is offline   Reply With Quote
