Old 02-07-2022, 10:05 PM   #1
1FAST SS
1FAST SS's Avatar
Drives: 2011 Camaro SS
Whipple Pulley Size
Need advice on pulley size. I am located in Northern Colorado (5,000 feet above sea level) which makes the pulley size more tricky. To make matters worse is there isn't any good LS shops in Colorado to get advice from. I have ID 1050 injectors and DSX Tuning low side aux fuel system. Other mods are in signature.
2011 Camaro SS Synergy Green
CAI Cold Air Induction, ADM Race Scoop, Apex Washer Bottle Kit, Vengeance Racing Kaotic Cam, DOD/VVT delete and LS3 conversion, American Racing LT Headers, American Racing Headers Off Road pipes, Borla S-Type Catback, FTI Billet Triple Disk 3600 rpm Torque Converter, DSS Aluminium Drive Shaft, AAC Plasma DRL's, Showstopper LED Sidemarkers,Carbon FIber Bow Ties, 35% Window Tint, Llyod's Floor Mats, JBL MS-8 Sound Processor, 2 Alpine PDX-1.600, Alpine PDX-4.100, JL Audio C5-650, JL Audio C5-650x, Alpine T10 Type R Shallow Mount, Stinger Dry Cell Battery
1FAST SS is offline   Reply With Quote
Old 02-08-2022, 12:33 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Give Ted at Jannetty a call and see what he says. They do a lot of FI work.
Old 02-09-2022, 08:23 AM   #3
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Rule of thumb is that for every 1/8" pulley diameter decrease, it equates to roughly 1psi of boost pressure increase.
I put the Whipple on my car when I was in Albuquerque, NM, which is similar elevation. With a stock damper and the 4" pulley supplied by Whipple, the car made about 600rwhp @7-8psi. On the 3.75" pulley, the car made 630rwhp @9psi. At that time I had LT headers, full 3" exhaust, ZL1 pump, ADM FPCM, LS9 cam, custom tune, and stock everything else. Those results were on 91 octane pump gas.
I have several 6-rib Whipple pulleys if you are looking for a certain size. Feel free to shoot me a PM.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 02-10-2022, 10:31 PM   #4
1FAST SS
1FAST SS's Avatar
Originally Posted by Batmanntexas View Post
Rule of thumb is that for every 1/8" pulley diameter increase, it equates to roughly 1psi of boost pressure increase.
Thanks for the information. I spoke to JDP and the recommendation from them was a 3.5" or 3.625. Based upon your numbers with 3.75" at a high elevation I'm wondering where it will fall power wise?
Old 02-13-2022, 05:01 PM   #5
Batmanntexas
With a cam and fuel supply, you could be in the 650-700whp range I'd think. As I mentioned previously, with the 3.75" pulley, my car made 630whp.
My current combo is using a 3.625" pulley, custom cam, ported stock heads, and fuel system. On 93, it made 746whp @ ~10psi, and 806whp on E85.
COTW 9/8/14
Old 02-14-2022, 08:58 AM   #6
fz4k98
Drives: 2013 1ss
Does the car need to be retuned if the pulley size is changed on a whipple? I am currently running a 4 inch pulley and use 93 octane.
fz4k98 is offline   Reply With Quote
Old 02-15-2022, 04:48 PM   #7
Batmanntexas
Ideally, yes. For a small change (1/8") you can get away without it, but any significant change will dramatically change the airflow. The MAF curve will be off as well as the speed density portion (VE/VVE table).
COTW 9/8/14
Old 02-17-2022, 06:34 AM   #8
eLeSthree
Drives: 2011 Camaro SS 6sp
Hey Batmanntexas, did you mean to say decrease instead of increase?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 02-17-2022, 02:52 PM   #9
Batmanntexas
Yep, good catch. Thanks!!
I'll edit the original post.
COTW 9/8/14
