Old 02-08-2022, 06:59 PM   #1
Shtiggs
Drives: 2014 Camaro 2SS Manual
What is the best fuel options for a 416 ls3?
I am in the process of building a 416 stroker and am shooting for around 10:1 compression and running around 15 lbs of boost max on the street. I currently have the stock ss pump and 850cc injectors. I know I need to upgrade but I am not sure where to start for this setup. I am open to meth injection so I can crank up the boot some when I visit the track but mostly this is a street machine. What are some good combinations of pumps and injectors and are there any potential snags I should keep in mind?
Shtiggs is offline   Reply With Quote
Old 02-08-2022, 08:30 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
AGP fuel system
I also think you'll need bigger injectors unless you plan on relying on meth for fueling but I would not. I would use meth only to cool, not fuel.
Old 02-09-2022, 06:28 PM   #3
Shtiggs
Totally understand meth is only for cooling. Just mentioned it because of the boost pressure, since I would like to be able to turn up the boot when tracking it. I am pretty sure that 1000cc injectors are good for this situation but was not sure if going slightly larger than that would put the injectors in a better duty cycle range.
I am running the AGP turbos and did not think to look at them for fueling solutions as well. Thanks for the link.
Old 02-09-2022, 10:29 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I have ID1700s in my vette and maybe hit 55% duty cycle at full tilt. I could have gotten away with 1300-1400s but didn't want to risk it.
Bigger injectors will give you more headroom as it seems everyone eventually wants more HP.
Old 02-10-2022, 10:58 AM   #5
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
What fuel are you going to run?
Pump, E85 flex or something else?
Also running too big of an injector can lead to idle stability issues as the injector will go into a non linear area at very low duty cycles. (<1ms)
You might be able to mask some of this by lowering base pressure and raising idle.
FasNuf is offline   Reply With Quote
Old 02-11-2022, 11:21 AM   #6
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Good advice. Listen to him . . . he has been around . . . seen it and done it.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 02-13-2022, 12:03 PM   #7
Slowhawk
Drives: 1999 Trans Am
On pump gas the 85's will work, just need more fuel pump. 2nd fuel pump,rising rate return regulator will definitely work.
I'd personaly run an alky meth kit. would have no problem going 1000rwhp with 93 octain/meth/ 850's.
Slowhawk is offline   Reply With Quote
