Old 02-09-2022, 11:22 AM   #1
Scotty D
Drives: 2014 1le 1SS CRMT
Send it ? Or stroke it ?
I am in need some advice???
I have a 2014 1le
I have an LSA supercharger thats going to be sent to Kong in the next couple weeks plus a brian tooley stage 3 torque cam , ADM 3 belt conversion, CHE bronze bushing kit, Affco intercooler , prospeed intercooler Expansion tank .. Plus a monster triple clutch with a mgw shifter .
Things needed 1050 injecters , 660 valve springs ! Will that cam even work in my LS3??
If so ? Should, i just install everything and send it ???
Or do a short or long block ??
Any advice would help guys thanks
Scotty D is offline   Reply With Quote
Old 02-10-2022, 08:35 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
The LSA supercharger is probably a bit small for a stroker. HP limitation on the SBE will be pistons and rods, but lots of guys running big numbers on SBE. 650hp is fairly conservative on the SBE. What numbers are you looking for?
Old 02-10-2022, 09:38 AM   #3
Scotty D
Id like at least 700 to the wheels
Old 02-10-2022, 09:41 AM   #4
Scotty D
There are guys making north of 750-800whp after port & that new X porting !
Thats what im going with myself the full service Kong offers !!
Old 02-10-2022, 09:52 AM   #5
CamaroCracka
I bought a set of wheels off a guy running a ZL1 with a cam, headers and pulley change running low 700s to the wheel and he was running circles around most of the cars at Sebring. Sounds like your build is right where you want it but porting the blower could give you a good bump. If you are sending it to Kong, they are probably the best people to talk to on what needs to be done to meet your goals.
Old 02-10-2022, 02:42 PM   #6
Scotty D
Awesome bro thanks for the input I appreciate it
Old 02-11-2022, 10:17 AM   #7
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
I am pushing 1065 to the wheels on an SBE but I have a centri that basically stays at zero boost until the hit. No two engines are the same but on a good tune you should be fine at your power level. May as well convert to E-85 if it is available in your area. Cheap race fuel, burns clean, and makes a lot of hp. Just saying.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 02-11-2022, 12:16 PM   #8
Scotty D
Was thinking the same on the E85
Thanks for your input bud
