Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 02-09-2022, 11:25 PM   #1
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Wtb 8 rib conversion for LSA swap
I’m looking for an 8 rib setup to put on my ss. The car currently has a 6 rib setup and I’m running into belt slip. Let me know what you’ve got
Pfa
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 04-14-2022, 12:59 PM   #2
SynergyGreenSS
Drives: 2011 2SS
Bump
2011 SS L99
Old 04-26-2022, 01:19 PM   #3
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
Just curious, what boost level are you at?
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM,
DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick,
ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop,NPP cat-back,
GM 3.91 gears, Eaton Truetrac, etc.
PhantomBlack is offline   Reply With Quote
Old 04-26-2022, 01:20 PM   #4
SynergyGreenSS
Drives: 2011 2SS
Around 10lbs. I’m on a 2.55 upper and stock ss lower. I haven’t been able to find any bigger 6 rib lower pulleys which is why I’m trying to get an 8 rib setup
2011 SS L99
Old 04-26-2022, 10:35 PM   #5
PhantomBlack
We are at the same boost level, but I noticed you have a blower cam so you have more efficient power than my NA cam. How did you notice the belt slip? Did the 6 rib belt actually move to a different rib on the 8 rib pulley? Burning belt smell/residue? I haven't noticed mine slipping yet. I've been keeping an eye on the tensioner and the line is still in the middle, hasn't moved a bit. I've got about 2,000 miles since the smaller upper pulley swap. What size belt are you running and is your pulley a Grip-tech? Sorry for so many questions.
Old 06-23-2022, 12:05 PM   #6
Scott S
Scott S
Drives: 2011 Camaro 2SS
Belt slip
I run an Innovators West 10% overdrive lower and a 2.40 upper on a 6 rib Gates RPM belt at 16lbs and no slip. What belt are you running?
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
Scott S is offline   Reply With Quote
Old 07-15-2022, 07:00 PM   #7
PhantomBlack
Wow at the HP level I see in your sig I thought there be some slip. Good to know.
