02-10-2022, 08:21 AM | #1 |
Naval Disabled Combat Vet
Drives: 2010 Gen5 Camaro LT RS Join Date: Feb 2022
Cat to Manifold Torque Specs
Anyone know the correct Specs for the Cats to manifold, This is what I have Don't know witch one is correct?
Catalytic Converter Nut Catalytic Converter Exhaust Manifold Nut 50 N.m 37 lb ft Catalytic Converter Nut 25 N•m 18 lb ft |
02-10-2022, 10:10 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Haynes manual says 15 ft/lb for manifold to head bolts; doesn't mention the cat to manifold bolts/nuts at all. Considering the size of the bolts I'd suspect the torque spec to be closer to 15 ft/lb, so maybe 18 rather than 37.
02-10-2022, 12:58 PM | #3 |
Torque bolts
Thanks I am Torqueing to 18 lbs
