Old 02-10-2022, 07:21 PM   #1
Greencamaro1234
Drives: 2011 Camaro LS
Limp mode
What’s going on with my car,I drove it 60 miles and would go to like punch the gas pedal and my car came up on my display,I think looked like a exclamation and then came up power reduced,stopped and cut it off a few minutes,cranked back up took off,went 15 miles or so,went to punch it again and the same thing with the sliding car in alarm,and reduced power,stopped again cut it off a few minutes cranked back off,and cleared all readings,and took off again and drove another 20 miles or so,and it didn’t happen again,any suggestions.
Greencamaro1234 is offline   Reply With Quote
Old 02-10-2022, 08:34 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Any mods? Throttle controller? I know with a throttle controller, hitting the gas quickly can set reduced power mode because the pedal position and throttle body position don't match (or something to that effect, forget what the code I got was exactly). If no mods, perhaps try cleaning the throttle body/valve as it's likely coated in dirty oil (even if a catch can's installed). Any codes pop up?
KillboyPowerhead is offline   Reply With Quote
Old 02-10-2022, 09:05 PM   #3
Greencamaro1234
Yep,have a throttle controller,although never use it and keep it on 0 at that,so might think about taking it off. Thanks
