Old 02-11-2022, 10:05 PM   #1
Duda
Duda's Avatar
Drives: Chevrolet Camaro 2013
Question about 2013 V6 Lowering Springs
Hey guys, I want to get some lowering springs for my 2013 LS. Eibach seems to be the most popular of lowering springs, but I'm wondering if anyone has them or has any other ones. Does the car feel a lot different when you're driving it? Honestly, the main reason I am considering them is because they look a lot better than stock height. Does anyone have them or have a similar spring (H&R)? Any feedback would be appreciated. Thanks
Duda is offline   Reply With Quote
Old 02-13-2022, 12:29 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
I had Eibach but didn't particularly like them; I found they were too soft for the weight of the car and/or reduced travel, and was bottoming out (springs fully compressing) much more frequently than with stock springs. JusticePete (Camaro suspension guru who doesn't appear to be too active anymore) always recommended BMR and Detroit Speed springs because of their higher spring rates (highest available besides coil-overs, I believe), so you may want to consider those.
KillboyPowerhead is offline   Reply With Quote
Old 02-13-2022, 03:35 PM   #3
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
I have the 1.5" DSE lowering springs on my V6 and love em. I also paired them with other suspension mods as well. Handles awesome!
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
