Old 02-12-2022, 01:59 PM   #1
Alpha11
Drives: 2012 Camaro SS
Catch can AND oil separator on a 1le
All right so I installed a catch can between my air oil separator and the intake. It hasn't been collecting a single thing. I learned recently there is a second crankcase vent to the left of the throttle body and it jumps over and feeds in to the right side basically right into the throttle body.
I think I'm going to throw the catch can between the throttle body and the crankcase and then just let my air oil separator vent to the intake plumbing.
Is anybody had any done this set up? It looks like most catch can setups just sit between one or the other. Now that I'm looking at my setup having a catch can after the air oil separator does seem silly.
Alpha11 is offline   Reply With Quote
Old 02-18-2022, 08:53 AM   #2
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Are you talking about putting a catch can between the stock, clean side separator, that runs to the intake tube? There is a little “U” shaped hose that runs from the passenger side, behind the throttle body, to the Valley cover port. You want to remove that hose, and install your catch can between that. If you are talking about the stock one, yeah you probably won’t catch much.
Coz3z3 is offline   Reply With Quote
Old 02-26-2022, 12:31 PM   #3
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Stock is “clean” side and really only “measurable” (which I say loosely) on the track. However; it isn’t designed to collect and be emptied out. You will certainly get the opportunity to empty a catch can on the “dirty” side, though.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
catch can, crankcase, oil separator, pcv
