Old 02-18-2022, 10:47 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Thoughts on setup
Decided to stick with the ECS kit, but just upgrade the blower. Too many parts to swap around with going TT. When it’s all said and done it’s 5k more for the TT. From the looks of it, easy 1000whp with the 2200r.
TMS 408
ECS 2200R
Should I just do the 2200X? Does the billet impeller really make a difference? With the X, I would have to upgrade to the 10rib setup, and that would be and extra 1k$
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 02-22-2022, 06:09 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I absolutely would do the x and 10 rib. surface area on the belt will only help a belt live and not slip at that power level.
Billet wheels make a big difference for us turbo folks. I'd imagine it would be the same for the blower guys.
ttshovel is offline   Reply With Quote
Old 02-22-2022, 10:19 PM   #3
RupertPupkin
At that point I might as well do the TT setup if going with the X. Going to the R doesn’t require the 10 rib conversion. Cost difference wouldn’t be as substantial
730whp: 630Trq
Old 02-28-2022, 04:52 PM   #4
eLeSthree
Drives: 2011 Camaro SS 6sp
It's your budget man, dont ask anyone else. 1000whp is a lot to handle in a stick car. Hopefully your clutch and fuel system is up for that.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 03-01-2022, 03:16 PM   #5
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
What are the goals performance wise?
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI
RealQuick is offline   Reply With Quote
Old 03-02-2022, 03:54 PM   #6
stevieturbo
Drives: it changes
Stick with the R....if you're not happy with it later, then re-consider
stevieturbo is offline   Reply With Quote
Old 03-02-2022, 03:55 PM   #7
RupertPupkin
I’ve accounted for the long block, fuel pump, and injectors. I’m just trying to swap out as minimal parts as possible when it comes to the FI part.
I know I have to swap my fuel pump and injectors out, and the clutch should be fine. Not doing any dig races, so my McLeod should hold up nicely.
1000 to the wheel, and a highway baby hauler. Lol
730whp: 630Trq
Old 03-02-2022, 09:55 PM   #8
cc-rider
Drives: 2010 Camaro SS
Can you elaborate more on what other mods you have already done? When you get to the 800+ range…heads, throttle bodies, and other things that are considered “little” gains at stock through 600hp range really start to deliver. Perhaps you already have those things done.
It’s all about displacement, airflow, and octane/timing in the end. Anything that affects that needs to be addressed to hit the 1k.
Sounds like a good build. I’m working on my blown engine now myself. But I’m shooting for the 800 hp level. Which you’ve already achieved. Good luck!
cc-rider is offline   Reply With Quote
Old 03-03-2022, 08:37 AM   #9
RealQuick
If its just a peak number you are looking for, then go with the blower... it should get you there.
Old 03-03-2022, 01:51 PM   #10
RupertPupkin
McLeod RXT
DSX Aux pump- swapping to fore triples or AGP triples
FIC 127lbs- swapping to ID1300/1700 or FIC 1650 (depends on shop)
ECS 1500- Going 2200r/x
Cam only LS3 (Blew up)- swapping to TMS 408
730whp: 630Trq
Old 03-03-2022, 05:56 PM   #11
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Nice, your torque will suck a hernia back in place when you are done. You're definitely going to need more blower to fill those additional cubes. Always better to go big from the beginning. Just like now you want to make the jump from 800 to 1000 hp then two years from now you will want 1200-1300. If you can afford it, put a big azz TT in so you have enough air no matter what you want down the line and call it good. One and done!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 03-05-2022, 03:16 AM   #12
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: sometimes
Some thoughts...
Originally Posted by RupertPupkin View Post
McLeod RXT
This is just general feed back. In the end you decide.
Not trying to threadjack. Just letting you know what works for me.
I went with a short-block with a 4.125 bore x 3.750 stroke = ~401 CID with performance heads and 10.8:1 flat tops and a Kong 2650. The bigger blower compared to the LSA is just a comparison to represent the increase in air input. Not meant to be a PD vs Centri vs turbo conversation. The greater airflow is all relative.
The shorter stroke has slower piston velocity than longer strokes combinations and allows for greater push by the boost. The longer strokes have faster piston velocity and require added boost to "chase" the piston that moves faster than the shorter stroke combination.
A6L90 transmission
Fore triple with return.
Cam is comparable to a BTR stage 4 (it has a lot of chop)
Using IDA 1300s to be able to use E85 and the 1300s tend to be more stable for drivability. If the engine ever needs more fuel I can always crank up the pressure at the regulator. Fuel trims on the tune are good and the Lambda averages .987 to 1.03.
The engine combo with the LSA blower made 810 rwhp. It was a handful then and even more now with the bigger Kong. The bigger blower makes an additional 140 and demands a bigger air intake and a NW103 throttle body. Still has great street manners.
Be sure to break in the new mill with a good zinc mixed oil.
Hope it helps. Good luck with your build.
PoleCat2SSRS2010 is offline   Reply With Quote
Old 03-05-2022, 11:28 AM   #13
hillshooter
Drives: 2015 Camaro SS commemorative
A6L90 transmission
One day they may even be able to prove old internet myths about short stroke on the dyno.
2015 Camaro SS
hillshooter is offline   Reply With Quote
Old 03-08-2022, 01:55 PM   #14
AGP Turbo
Drives: All things Turbocharged
You've got to overcome worrying about +- a couple thousand dollars. Keep in mind the cost of boost control that will become super important to you once you have 1000+ whp. And keep in mind the going TT will need 15% less fuel delivery since you aren't loosing 15% to spin the blower up.
And lastly, if a couple thousand bucks is going to break the bank for you, then for sure don't pursue building 1000+whp car.
AGP Turbo is offline   Reply With Quote
