Old 02-21-2022, 09:26 AM   #1
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Quick video on 1 piece driveshafts
I recently have had a few different people ask some questions about 1 piece driveshafts and why we would recommend one. I was way overdue for some new content on my YouTube channel, so I figured a quick 1 minute video for 1 piece driveshafts was in order. Maybe this helps this group a bit.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 02-22-2022, 08:43 AM   #2
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
the amount of slack in the stock driveshaft is insane.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 02-22-2022, 09:05 AM   #3
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Agreed
I just installed my new DSS one piece 3.5" driveshaft over the weekend. What a huge difference. All of my steering wheel shake is gone on the highway and the car feels more responsive and snappy. My car only as 39k miles on it and the center coupler on the 2 piece driveshaft gave out and the rubber boots crumbled when I pulled the shaft out. I would highly recommend anyone considering a one piece shaft to just do it!
Follow me on instagram @Cthulu_the_trans_am
https://www.camaro5.com/forums/showthread.php?t=600181
2011 Camaro 2SSRS - Sold
No longer a 5th gen owner, but still an enthusiast. Ask me about my Front crash bars!
The_bald_eagle_machine is offline   Reply With Quote
Old 03-14-2022, 10:08 AM   #4
Scotavo
Drives: 2013 Caprice PPV 2014 Caprice PPV
My "Camaro" is a 2014 Chevy (Holden) Caprice PPV. The guys at The Driveshaft Shop in N.C. gave me all the info I needed for them to make me a carbon fiber DS. They said I could get most of what I wanted with their aluminum one but at ~600 ft lbs torque from the LSX from The Hot Rod Company of Green Acres (really) Washington, US the OEM or any two-piece was a really bad idea. Honestly the CF DS is better than I even imagined. While it's fairly long because it's for a Caprice, it does everything well. I recommend them.
Scotavo is offline   Reply With Quote
Old 04-20-2022, 06:43 PM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Looks like you removed the heat shield? Also what did you use for a safety loop?
camguynj is offline   Reply With Quote
Old 05-11-2022, 11:19 AM   #6
camguynj
camguynj's Avatar
From the pics it looks like you installed an aluminum one piece driveshaft, correct? Did you experience making more shifts/sooner shifts from 1st to 2nd when just DD? What rear gears do you have? Thanks
Old 05-11-2022, 01:12 PM   #7
acammer
acammer's Avatar
You are correct - the heat shield is not gonna work with the 1pc driveshaft. I do not have a driveshaft safety loop in the car presently. It would be worth doing at some point for sure. Until then, in DSS I trust.
I'm not sure your shifting question was directed to me, but it didn't change anything about daily driving shifting. Under full power it's a benefit because it's one less item flexing around in the driveline, and keeps everything more direct for the transmission.
Old 05-11-2022, 01:40 PM   #8
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Definitely on my list for this winter along with a truetrac. Good stuff as always acammer
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 05-14-2022, 07:35 AM   #9
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Can you post a video link. I can’t get the video to work
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 05-16-2022, 06:29 AM   #10
acammer
acammer's Avatar
Give this a try: https://youtu.be/Do12rtaDizY
