02-23-2022, 01:19 PM | #1 | |
Drives: 2010 Camaro LLT V6, 2018 Silverado Join Date: Sep 2020
Oil Pressure Issues at cold start
For background reference Please see post:
Timing Chain Idler Sprocket bolts starting to get off topic so I started a new thread. Quote:
I replaced the filter cover with the built in pressure relief valve and its the same. I tried 3 different cartridge filters and the AC Delco branded filter actually made it worse. Running without an oil filter builds up very very little oil pressure for some reason. I will be replacing the Oil pick up tube gasket in the coming weeks to see if that makes a difference, I will also be inspecting the oil filter housing and weird little valve I've seen on some GMC Acadia forums that's in-between the oil pan and filter housing. I'm thinking that I have a leak or blockage in the oil system. I have tried 0w-30 motor oil and that seemed to help with the cold starts. 10w30 made it way worse so I don't think it's wear in the mains or the timing system. At idle and at operating temp I'm getting 28 PSI on the gauge, 70+ at cold start and 70+ under acceleration. Post from Acadia Forum: https://www.acadiaforum.net/threads/...k-valve.33041/ Last edited by Davval; 02-23-2022 at 04:19 PM. |
