02-25-2022, 11:08 AM | #1 |
Drives: 2010 2SS Join Date: Sep 2021
Traction Control and 3.91's
For those of you running higher horsepower or lower gears, how well does the traction control work with performance radials (not drag) on the street?
I am installing rear suspension mods/bushing etc. from BMR and drag radials on the strip. CAI and LT headers will be going on this year. Considering adding 3.73's to my automatic trans car when i install the Eaton True-Trac. I just bought my car in February and given the weather in Montana haven't played around much with the traction control. I assume it still works with higher horsepower or lower gears but it would still take off fairly slowly under full throttle as it pulls power when the tires slip. Can you roll into full throttle and still accelerate hard without slipping? Currently the car is faster in the 1/4 mile with Traction Control on due to the cold weather and winter tires. I really don't want it to break the tires loose when i shift down to pass someone on the highway. For normal driving in town and on the interstate does the traction control work fairly similarly to the way it does stock (reasonable acceleration but slower off the line than when using drag radials)? |
02-25-2022, 11:21 AM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Traction control will only go so far. If you keep your foot in it. it will keep going. It will just slow it down.
You can roll into throttle without losing traction with or without traction control. That depends on how well you know your car. If you are running a lot of power, do you really need to downshift to complete a pass. My car will pull hard enough in 6th to make highway passes unless someone thinks we are in a race, and then I have to decide if we are really in a race or not. Generally not.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-02-2022, 12:04 AM | #3 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Traction control from a dig just slows you down. My personal expirence: I jumped out on a 10 speed mustang by a car with traction off and it dead hooked. Won by a car. We sat for a while and we made another hit, I forgot to turn traction off, and it just flashed at me all the way through 1st gear for no reason because it dead hooked. We were dead even off the line and he got me by a half car.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
03-02-2022, 12:30 AM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I think that with stock tuning you will be fine with the traction control on taking off from a dig or especially on passing. The traction control will pull timing and close the throttle to limit power in a traction control issue. I seriously doubt that you can even break the tires loose on passing unless it's wet out and even then your traction control will kick in pretty fast. Now if you turn off your traction control that's a whole nother story.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-02-2022, 07:27 PM | #5 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
3.91s ftw.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
03-02-2022, 07:59 PM | #6 |
Drives: 15 Camaro SS Join Date: Oct 2018
391 is a great mod. Would like to have something that disables traction control permanantly. Even shutting mine off the proper way, for some odd reason it stills kicks in every once and a while
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
03-03-2022, 07:01 AM | #7 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
03-03-2022, 07:57 AM | #8 | |
I didn't even do the Eaton, just a swap. My car is definitely a factory freak. It takes a beating and just doesn't look back.
