Old 02-28-2022, 12:05 PM   #1
thebluecamaross
thebluecamaross's Avatar
Drives: 2010 Camaro 2SS/RS ABM
Brake & Clutch Fluid - Bleed, Flush & replacement HELP
Hello All,
I need some advise, but most importantly, clarification on the brake & clutch flushing/replacement process for our 5th gen cars. Please pardon the ignorance.
1) Since the clutch and brake fluid share the same master reservoir, is just bleeding the brakes sufficient to bleed the clutch as well or is there a separate process for that?
- Is there a good thread to follow on the bleeding of the two components? Also, what tools do you recommend me getting.
2) I bought the Separate clutch reservoir from JDP sports and I wanted to know if it's best to do the flush now or after I install the clutch reservoir. I imagine at that point I'd need to bleed each component separately.
- Is there a good thread for reference for tools needed and steps to take?
THANKS!
thebluecamaross is offline   Reply With Quote
Old 02-28-2022, 12:43 PM   #2
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
No, the brakes and clutch do not interface that way. The resevoir yes, but not the lines. I would do it after, but thats just me. You should read through this:https://www.camaro5.com/forums/showthread.php?t=219270
MSgt O is offline   Reply With Quote
Old 02-28-2022, 01:23 PM   #3
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
I've had the separate clutch reservoir on my SS since 2010. It's easy to change the fluid on them. I just suck out the old fluid and put new fluid in. I then pump the clutch pedal about 10 times, then suck out the fluid again, which is still dirty. I do this till the fluid is clean again.
sscamaro is offline   Reply With Quote
Old 02-28-2022, 05:15 PM   #4
fz4k98
Drives: 2013 1ss
The only way to get it all is at the end of each line at the bleeder. I had real clean reservoir fluid from many clutch bleeds and then did the brakes and the fluid was black at each bleeder.
fz4k98 is offline   Reply With Quote
Old 02-28-2022, 09:03 PM   #5
thebluecamaross
Hey Man, thanks for getting back.
So, do you bleed the clutch fluid (from the separate clutch reservoir) from the clutch bleeder valve thats on the side of the transmission?
I'll need to know the process for when I actually install the separate reservoir. Thanks!
Old 02-28-2022, 09:04 PM   #6
thebluecamaross
Old 03-01-2022, 12:20 PM   #7
sscamaro
I have a thing that is pump that pumps fluid out of a container , I can suck out the fluid into a coffee can. I stick the tube in the clutch reservoir and press on the handle, which sucks the fluid into the can. I don't remember what it's called or where I got it. I'll take a picture of it and try to post it on here.
Old 03-01-2022, 01:19 PM   #8
MSgt O
MSgt O's Avatar
You CAN use the bleeder on the side of the transmission. But, when i did mine, I used a turkey baster and just removed fluid, pumped the clutch, removed fluid, replaced with new fluid, pumped the clutch, removed and added fluid, pumped the clutch, and eventually it'll be clean. SS most likely has a vacuum pump that is usefull, but a turkey baster works, just slow.
Old 03-01-2022, 02:33 PM   #9
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
All the suggestions I see here are great. Without a pressure bleeder what I do is remove all the fluid from the reservoir, refill with new fluid, then gravity bleed each thing individually. Start with the clutch, open the bleeder and let it go for about 2 or 3 minuets. Then l/f wheel a min or so , r/f maybe 2 min, rear wheels about 5 min. All the old fluid should be out by this point.
NOT A 45 is offline   Reply With Quote
brake bleed, clutch bleed, clutch separation, flush
