Old 02-28-2022, 01:04 PM   #1
Surfdog SS
Surfdog SS's Avatar
Drives: 2015 SS Black/Black
Meth?!?
I finally got my ECS kit in, ordered it back in Sep from a vendor who not to be named. I'm already thinking about my next mods lol. I'm thinking about adding a meth kit so I don't have to worry about messing with the fuel, since the sc kit comes 60lb injectors and a bap. What your thoughts on the newer snow kits with the trunk tank, braided lines, and boast gauge controller? Is anyone still using Meth or have they gone to e85?
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Surfdog SS is offline   Reply With Quote
Old 02-28-2022, 01:31 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I inherited a Snow kit with a used turbo kit. It was the original stage II with a solenoid and controller box. The Box failed after a while and I replaced it with Harris Performance Controls until. The pump works fine, but I did upgrade replace the nylon lines with stainless ones from a nitrous kit. I also converted the Snow pump to 3/8 npt with a pump top from Devils Own.
Meth definitely cools the intake charge allowing for more boost. I run 100% because I use the same fuel source to feed the nitrous, which is also why I switched to stainless teflon lines. I wanted to minimize the chances of a leak and push connect fittings leak if you have to disconnect and reconnect them with any frequency. On 100% I could see a 20* drop in IAT as soon as the meth kicked on. I use it mostly as added insurance meaning I don't add timing based on the meth.
A lot of guys swear by Alky, but I look at the systems the way I look at nitrous. Most of the parts are not manufactured by the sellers, e.g. Parker makes tons of the solenoids used for nitrous various manufacturer's systems, I look more at what is included in the kit. You want a solenoid connected to your triggering system, stainless lines, brass or stainless fittings, and a reliable pump. As far as I can tell, the pumps are all similar and they just use different internal regulators to increase the pressure and put their label on them. I have compared Snow jets to Devils own side by side and the Devils Own atomize better. Good luck.
Old 02-28-2022, 02:16 PM   #3
Surfdog SS
Surfdog SS's Avatar
Thanks appreciate it, the newer Snow kit comes with a solenoid, braided lines, hard anodized fitting(I think that's good), boost gauge/controller, and throttle body spacer for the injectors. It seems like the kit is much better then the older ones.
Old 02-28-2022, 04:48 PM   #4
Rob3D
Rob3D's Avatar
Drives: Car
ALKYcontrol is in Tampa and you will not get better customer service from any company selling anything! Julio is the man. He’s walked me through numerous setups and install as well as any other questions you might have. He uses email, text and phone of course. You send him a picture of something he’ll tell you how to correct it or install it.
Rob3D is offline   Reply With Quote
Old 02-28-2022, 05:03 PM   #5
BatmaroBeauty
BOOST OR BUST
BatmaroBeauty's Avatar
Drives: 2010 Camaro 1LT
+1
Personally recommend Julio at Alky also. Great guy, seriously cares about the wants/needs of his customers. Took the time to discuss with me about current mods and goals for the build to identify best purchase specific to my needs of water/methanol system application.
Batmaro=The Bane of My Existence ⠀⠀⠀⠀⠀ ⠀ ⠀⠀⠀⠀⠀⠀ ⠀ ⠀ ⠀⠀⠀ ⬋LIKE AND FOLLOW THE BUILD ON INSTAGRAM⬊
BUILD STATUS: LOADING BOOST . . .
BatmaroBeauty is offline   Reply With Quote
Old 02-28-2022, 05:51 PM   #6
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
We have been using Alky on all our cars for years. No issues.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 03-01-2022, 08:01 AM   #7
Surfdog SS
Surfdog SS's Avatar
Has anyone used the Snow throttle body insert/spacer for the nozzles? Is this to close to the intake manifold?
Old 03-01-2022, 08:35 AM   #8
Carpetguy
Carpetguy's Avatar
Drives: 2011
I have Alky meth kit.With the trunk tank.
Tank is a pain if have to change the pump.
When I got the car it had the plastic lines.
Called Julio at alky and he set me up with braided lines.And definitely helped me out a few times.
Definitely would recommend Alky
Carpetguy is offline   Reply With Quote
Old 03-02-2022, 09:31 AM   #9
CamaroCracka
Never looked into a meth plate, but I purposely split off my IAT from the MAF and moved the nozzles just after the MAF to get the max cooling effect and be able to tell what the IAT was going into the TB. The evaporation is what cools the charge and it takes time, not a lot, but some.
Old 03-13-2022, 01:41 AM   #10
K8811ss
Drives: RS/2SS white/black
Personally, I would go E85. Especially if you have pumps around where you live. It's easier to get and no separate tank.
UPP 58mm TT, 127lb per hr. Injectors, e85 flex fuel w/ duel Areomotive fuel pumps, TSP stage 3 blower cam 900+hp 9.5psi
K8811ss is offline   Reply With Quote
Old 03-13-2022, 07:50 AM   #11
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I use the AEM progressive controller with all prometh lines, pump, tank, and nozzles. The AEM controller is so simple to wire up also.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 03-16-2022, 10:04 AM   #12
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
I run alky dual nozzle system... works good. I run straight meth and it drops my intake temps 30-40 degrees below ambient.
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI
RealQuick is offline   Reply With Quote
Old 03-16-2022, 11:18 AM   #13
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
I second this, and never skimp out on fueling especially going forced induction.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 03-16-2022, 12:42 PM   #14
RealQuick
60lb injectors and bap is fine for 93 octane on a stockish motor. E85 will require more injector if you want to go that route
