03-01-2022, 06:44 AM | #1 |
pete1le
Drives: 2013 Camaro 2SS RS 1LE Join Date: Aug 2014
Discontinuation of 1LE axles
It appears that GM have discontinued the part for both the left side and right half shafts for the 2013 SS 1LE:
Part numbers: 22806795 (Left), 22806796 (Right). Can anyone recommend a suitable after-market part or suitable OEM part. Not sure if ZL1 axles would work with the 3.91 final drive ratio of the 1LE. Any help with this would be appreciated.
03-01-2022, 07:41 AM | #2 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Gearing would have have no effect on the axles. So long as the length and splines are the same, they’ll go in.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
03-01-2022, 09:07 AM | #3 | |
pete1le
Thank you :-)
03-02-2022, 07:40 PM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
ZL1axles will not fit in a SS/1LE/Z28 Diff.
Orange Krush II
07-04-2022, 09:26 AM | #5 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
I just installed z/28 axles on two 1LEs. If you can find them they work, all is same but the grease and booths are higher temp rated.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
07-04-2022, 09:41 AM | #6 |
pete1le
Thank you, I will see if I can find the part numbers for the Z/28 axles. Thank you.
07-04-2022, 11:54 AM | #7 |
