New Build From Columbia, SC
This a 2010 with 128k on the dash. runs like a dream, super fun weekend car.
I bought her in September 2021. Camaro Parts list: updated 08/5/2023 ZL1 front grill ZL1 front bumper Z28 CF Hood Vent 3000k LED fog lights 6500k LED headlights LED Sidemarkers Avil CF Rear Spoiler Matte Blk Tail light Bezels BC adjustable Coilovers STOPTECH SS Brake Lines Hawk Ceramic Yellow Pads Hotchkis Front/Rear Swaybars Hotchkis Front/Rear Endlinks Z28 Front LCAs Z28 Radius Rods Whiteline P/S Rack Bushing Whiteline Rear Subframe Bushings Whiteline Differential Bushings GM inner/outer toe rods Z/28 Rear UCA Bushings Z/28 Rear Z/28 Wheel Bearings Z/28 Rear Axles UMI Rear Toe Arms UMI Rear Trailing Arms CSF Aluminum Radiator GM Waterpump 160° Thermostat MightyMouse Catch Can ATI Harmonic Balancer GM Belts Kaltech Adjustable Belt Tensioner GM Engine Wiring Harness GM Knock Sensors TSP 10mm plug wires NGK TR61X sparkplugs EVAP relocation kit Intake scoop w/ AirRaid Intake BoWhite Ported TB Earls 8AN Fuel Lines/Fittings Holly EFI Sniper Fuel Rail Holly Tall Valve Covers TSP Titanium Spring/Retainers Titanium Valve Seals TSP Cromoly pushrods Manton Bronze Trunnions LS7 lifters LS9 HeadGasket RollMaster Chain/Adjustable timing LS2 Chain Damper ARP Cam Bolts .629/.644 TSP Stage 2 Cam ARP Head bolts KOOKS Headers Gutted Kooks Converters MagnaFlow Muffler Custom 2.5in exhaust Hurst Short Shifter Centerforce SST Twin Disk Clutch CenterForce Hydraulic Slave Cyl. HPtuners AEM wideband Defrost vent Gauge Pod ******** Amp kit for Factory Radio Alpine 4channel 1000w amp Alpine Type R 6.5 w/tweeters Alpine Type R 6x9 components Drake Pedal Covers Master window switch Trunk switch GM E-Brake Cable GM TPMS Sensor (4) thanks for looking. comments are welcome Last edited by Leadsled; 02-29-2024 at 02:42 PM. Reason: Parts list |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Welcome
Nice ride and welcome to the group! Your Camaro is looking good so far. Good taste in mods so far. My car is very similarly modded and so far it has been a blast to own and drive.
Follow me on instagram @Cthulu_the_trans_am
https://www.camaro5.com/forums/showthread.php?t=600181 2011 Camaro 2SSRS - Sold No longer a 5th gen owner, but still an enthusiast. Ask me about my Front crash bars! |
Its really fun! wheels and cam are next.
Welcome & nice ride!
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
#6 |
Quick update: added the windsheild washer tank delete/intake duct, also did the heater hose relocation. added some yellow fog light bulbs too.
TSP stage 2 cam is on the way with valve train package. Going with Melling high pressure oil pump and ATI pully. My AEM wideband and HP tuners showed up earlier this week. Last edited by Leadsled; 04-13-2022 at 07:31 AM. Reason: adding picture |
#7 |
not bad for a 2010
#8 |
![]() Drives: 2015 Chevrolet Camaro 2SS Join Date: Apr 2022
Damn right that's sweet!
She's in incredible shape for a 2010, and looking sweet!That grille cut out I've never seen that before that's something new to me I like that!I just got a P0452 engine code thrown up yesterday on mine,EVAP system.They say more often then not it's a loose gas cap,I checked that today but it seemed fine.My next worry is I smelled what I think might be a wire burning the very night before the code got thrown,and I'm hoping a squirrel hasn't chewed through a wire and caused that EVAP system to screw up.We have a squirrel infestation here and a friend of mine had them chew through wires and his fan blade tips and told me to spread out cayenne pepper on my carport to keep those bastards away.
#9 |
Oh nooo. You may have to replace the cap if it’s not getting a good seal
#10 |
Anthony S
Your Camaro is coming along nicely. Lot's of mods in a short amount of time!
#11 |
Thank you. I went to the track this weekend to get a feel for the car. before the CAM swap. I really could use more seat time. My best was 13.3 @114mph. lots of room for improvement. i dont think its horrible for my FIRST time at the track. Any recommendation on launching? The tires are shitty Kumos I know a good tire will help but these are brand new
#12 |
Although I will probably wait till winter of 2022 to install... Most shops are 4-5 weeks with turn around time with Porting LS3 heads. but here's a parts list so far.
TSP 229/244, .629/.615 TSP .660 dual valve springs w/ seat/seal PRC Titanium Retainers TSP Chromoly Pushrods Rollmaster LS3 Single Roller timing set Manton Bronze Trunnion Kit ATI Crank Pully LS7 GM Performance Lifters and trays BT LS9 HeadGaskets LS9 Injectors -- pending LS9 Spark Plugs -- pending GM Flex Fuel kit -- pending Holly Valve Covers Holly EFI Sniper Fuel Rail AEM Wide Band w/ single vent POD Russel 8an Fuel Lines and Fittings HP tuners Gaskets--- all the Gaskets, Car has 113k on the dash Im sure im forgetting something. But the plans are to port the stock heads and GPI rod-mod intake and ported TB. Comments are welcomed ... This is my first V8 build hoping for 500whp Last edited by Leadsled; 04-27-2022 at 08:03 AM. |
#13 |
So, since I bought the car and I had it in the air I was embarrassed by the shade tree mechanic/ fence post / truck tips 🙃. Thought I would change things up and create something I can be proud of. I went with magnaflow X pipe. I’m routing the pipe for enough room for 3.5 differential. And I have the Solo Performance axle back with w/ J pipes. And 4.5inch tips
#14 |
My little "parts shelf" I installed the Mighty Mouse Catch Can, also did the fuel rail flip and Evap sensor relocation. We have a date for the Cam install but I could not leave the car alone.
