Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 03-04-2022, 07:06 AM   #1
SmokinRam
Drives: 2013 Camaro ZL1
2013 ZL1 Drag Wheel/Tire Advice Needed
Hi everyone. I am sure this topic has been beat to death through the forums but I am hoping someone can give me some quick info to help.
I was planning on ordering a set of Weld Wheels and MT tires from Carlyle Racing but just found out BMR bought them and they don't do wheel/tire packages anymore. So I am planning on spec'ing out my own setup and wanted to know the exact size wheels and tires I should be looking for. Want to run 17's in the rear because I don't have the 15" brake conversion kit yet.
Please let me know your comments if you can.
Thanks in advance,
Andy
2013 IOM ZL1 A6 - 680RWHp
2002 ProCharged Trans Am - 850RWHP
2006 Twin Turbo'd Dodge Ram Cummins - 900RWHP
2015 VW Jetta TDI SE - Daily Driver
SmokinRam is offline   Reply With Quote
Old 03-04-2022, 09:00 AM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
MT ET Street R - P305/45R17 w/ matching wheels.
JB'sZL1 is offline   Reply With Quote
Old 03-04-2022, 10:14 AM   #3
SmokinRam
Thank You. Do you know the wheel size with backspacing that I need?
Old 03-04-2022, 10:51 AM   #4
JB'sZL1
Size 17 x 10.5"
Bolt Circle 5 x 120"
Back Space 7
Offset 32
You can go Weld on the high end, Racestar on the low end.
Here's Prostock John's sticky: https://www.camaro5.com/forums/showthread.php?t=392950
Old 03-04-2022, 11:03 AM   #5
JB'sZL1
And, if you are unaware, with most 17's you will have to tie back the emergency brake cable and notch the lca's.
